- oem itr in a b16 tranny?
- Quaife lsd come with speedo gear??
- clutch will not disengage above 4000rpms
- Interested clutch problems
- Recommendations on grinding tranny
- NEED NEW TRANNY! I can see inside the old one.
- Tranmissions, what do you have to say?
- Need help diagnosing cause of tranny rattle, maybe input shaft bearing (video)
- ls 5th in gsr??
- S2000 Slave/Master replacement
- Tranny Diagram!!!!!!!!
- LS AUTO TO Manuel
- torque converter b16???
- Tranny fluid question????
- type R LSD in an LS or B16 tranny
- TL TYPE S j series tranny help
- act disc and stock pp. will it hold up??
- Reverse problem.
- why use all your gears??? kind of a dumb question....
- HELP WEIRD TRANNY PROBLEM!
- TYPE R TRANNY good for HIGH BOOST???
- difference between 4.4 and 4.928 final in 1/4
- Gearing affects on 1/4 mile for a single cam.
- obx lsd install into m2a4 problems
- help with install of the ball bearing on top of the mainshaft
- Please Help!!! Replaced Clutch, slave, master cylinder?????
- big difference from 4.266 to 4.4 final drive?
- transmission troubles on my new setup :(
- 2nd gear slips out need help!!!
- D-series LSD install and new synchros
- Detailed Questions of Diferrence: LS VS. GSR Tranny
- Gsr Transmission question
- Can we have transmission tech time?
- integra automatic starts to die when put in gear
- I need a cable tranny service manual
- Is my clutch/flywheel/throwout bearing going out?
- Recommend me a new clutch
- Clutch issues: No pressure from master cylinder
- tranny squeal! what could it be?
- trans problem
- gsr tranny lsd
- quick b16 tranny question
- ITR LSD question
- ***Clutch or Transmission Problem*** (PLEASE HELP!)
- tranny swap question
- Is overfilling an automatic tranny bad ???
- Tranny and LSD expert needed to I.D
- FIrst time LSD install
- ITR vs. GSR clutch?
- LSD repair how much for labor
- Gearing questions.....
- tranny issue
- help!
- Help deciding on a clutch - ~200 wtq
- not your tipical...clutch wont disengage. cant go in gear!!!
- is it my clutch or maybe something else
- Know where to get m2b4 trans complete swap kit for 97 prelude?
- Civic Transmission is slipping...I think
- New rebuilt LS lsd trany ys1 proublems...
- axles help
- tranny swap need info on the H2B kit (b16 trans with h22)
- What kind of LSD do i have??
- lsd help
- Clutch engaged?
- HELP PLease!!!! Axle or tranny???
- Quaife vs. OEM type R LSD for my street driven boosted GSR
- I need B series synchronizers!!
- help! Transmission problem
- Is there something wrong with my diff ?
- What to do to put a B-series tranny on a h22 motor
- Pulling hair out over tranny issue. Wont shift high rpm after new clutch.
- GSR tranny rebuild
- Tranny fluid...
- ITR transmission in 01 B18B1
- Stock GSR pressure plate clamping force?
- EX MT won't go into gear, yes I adjusted the CMC...
- CRV 4wd Tranny gear swap? HELP!!!
- CG tranny onto a d16z6 - everything you wanted to know
- help on b20 automatic swap (TCM)
- tranny noise - whirring / whining / humming
- ***Aftermarket Gear Failures?***
- which gears are available for 5th gear replacement in gsr lsd tranny?
- Liberty Gear cuff link HELP
- Automatic Transmissions and Torque Converters Explained
- LSD problem ...
- Need Assistance: engine stalls when pressing the clutch
- Transmission Topic Index/GOOD LINKS/ETC.
- Gears Grinding?
- Which is a better tranny Y1 S1 J1 ?
- HOW TO: Field strip an OBX LSD
- ats close ratio gearset for itr + 4.9 final drive - fitment issues with 4th gear...
- How to fine tune your gearing for optimal 1/4 mile acceleration.
- 98-01 CRV 5speed gear ratios?
- Civic Hx Cvt tranny help (automatic) will it work with other D-series auto transmissions?
- Clutch Type LSD User Fluid I Discovered - (Kaaz, Spoon, OSGiken, ATS CROSS) DC5
- Clunking noise from tranny after clutch replacement
- What is the top speed for each gear? (GSR)
