PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31
  1. 1st gear cruncy
  2. crv transmission weight
  3. Broken Diff or Broken Axle
  4. My transmission needs help!
  5. 4th gear linkage? Synchro?
  6. EK9 LSD in a non LSD J1???
  7. JDM Type R trannt w/LSD
  8. Broken Diff?
  9. torque steer w/ mfactory diff help!!
  10. Transmission Pros - Can you identify if M2A4?
  11. Just picked up an ITR and ran into tranny/clutch problem... help please
  12. 3rd gear grind on a gsr...how many miles until syncromesh does anything if at all?
  13. Did ISB and now car won't go into reverse!
  14. How many miles are on your clutch?
  15. how to get dohc zc tranny synchros
  16. LSD and Final Drive for boost...
  17. shift linkage question
  18. tcu Code 15
  19. gsr tranny help
  20. Do torque converters go bad?
  21. Axles???
  22. ITR LSD into b16 tranny ***HELP****
  23. Whats everyones take on the Quaife LSD???
  24. spring washer on main shaft
  25. rsx gears in besries tranny????????????
  26. kaaz 2 way lsd users ?
  27. h22 Clutch replacement help
  28. Clutch vibrates, won't disengage, help!
  29. WHP & WTQ w/ different F/D's
  30. LSD Question
  31. How to tell difference in b16 to gsr hydro tranny diffs
  32. stage 5 competition clutch
  33. Need help Shift engagement issues after installation???
  34. how to tell what transmission i have ?
  35. obd0 b16 cable trans on LS motor
  36. Looking for some input on rebuilt kits
  37. B-series gearbox Conversion
  38. Stock B pressure plate clamping load
  39. Cable Ls case with cable B16 internals?
  40. Ls tranny with gsr final?
  41. d series auto to b series manual
  42. 500 mile breakin period?
  43. driver side drive shaft set ring??
  44. D Series automatic tranny question
  45. for a tranny guru...b16 issue
  46. B16 Tranny
  47. CV axle dynamic dampener needed?
  48. Special bolts for transmission swap
  49. where to buy a good D15 5speed tranny?
  50. Input shaft bearing
  51. itr gears?
  52. synchro sleeve sets same for B-series? Or reverse gear the same?
  53. H SERIES + Tilton clutch
  54. 00 civic ex AUTO TO MANUAL
  55. will a eg shift linkage bolt right on to a LS tranny??...HELP ASAP
  56. shift linkage
  57. LSD Clutches / Flywheels B16
  58. how much tranny oil in J1?
  59. Are honda / acura clutch master cyl's the same?
  60. Which trans is better?
  61. Bay Area Tranny Shop In Need, 5 Speed Swap 92 EG
  62. calling all honda builders!!
  63. b16 trans in a 1994 gsr
  64. will a 94-01 diff fit into 90-93 diff
  65. HELP!! 2002 Honda Civic EX transmission problem???
  66. so.....i dropped a piece of metal into my crankcase.....
  67. Help!!! identifying b series Tranny
  68. shift fork ?
  69. anybody heard of a gsr tranny with phantom grip
  70. Type-r lsd in a gsr tranny
  71. First Gen B-series cable trannies question
  72. GEAR-X and Mfactory Joint Statement
  73. help: bleeding clutch master cylinder
  74. 89 trans and 99 trans
  75. Shaft play
  76. rattling trans noise
  77. b16 tranny oil
  78. lucas oil-gear clash problem
  79. honda civic master cylinder noise
  80. 5 speed shudders in 1st gear
  81. Prelude gearbox problem
  82. Lightened Flywheel?
  83. what clutch?
  84. zc tranny question
  85. how are f1 clutches? please help
  86. 2nd post: Lost 5th gear w/new clutch-HELP!
  87. popping out of gear
  88. Dropped a washer into my transmission. How to get it out?
  89. I've burned up 2 automatic trannys in less than 2 months, HELP! ???
  90. swapping b16 gears into gsr tranny?
  91. i have tranny question and i have a lazy question
  92. help with gsr trany..>>>>
  93. converting small shaft to big shaft cable?
  94. axlesnd tranny cant find them?
  95. f23a1 manual tranny not coming off
  96. test test
  97. Stock 97 Accord differential problems
  98. Help changing the final drive???
  99. longer 5. gear H22A
  100. Tranny stuck in gear
  101. Leak from Differential?
  102. leaking from shift linkage on gsr tranny
  103. can't shift into gears while car is on....
  104. Just put together my GSR transmission.
  105. h22 trans issues
  106. noob dont know if its lsd
  107. noob dont know if its lsd
  108. Tranny sticker
  109. B-series tranny onto d16y8?
  110. Problem with lower control arm bolt
  111. My gears are super notchy!! sometimes doesn't even go in!!
  112. 1998 Acura CL 3.0 Transmission problem
  113. Quaife LSD and Tranny fluid question
  114. Cant shift out of park
  115. Y80 rough spin after rebuild
  116. b17 half shaft seal
  117. How engine-specific are B-series clutches?
  118. leak at end of select wire please help!
  119. How a differential works - By GM
  120. GSR transmission identety question.
  121. mfactory lsd install, bearing/part questions
  122. Ok noob question
  123. Does everything look correct in my transmission
  124. car wont shift please help
  125. Hydro to cable swich
  126. Howl?
  127. transmission guru's need help
  128. vibration when leting clutch out between gears
  129. 1st and 2nd Gear Problems.
  130. 01-05 civic clutch fit eg si?
  131. need your input on gsr transmission noise
  132. 700+whp tranny setups......all racers post your setups
  133. Clutch kit missing bolts
  134. '92-'95 civic automatic and manual trans axles
  135. Mainshaft's interchangeable???
  136. ls tranny in eg problem...urgent
  137. Putting gears and shift forks in troubles
  138. b series tranny gears for 1/4 mile
  139. Broken countershaft where it connects to the ring gear
  140. Tranny that screams!
  141. More than one transmission issue.
  142. 06 tranny not going into first
  143. y21 trans
  144. my gsr transmission is stuck on 2nd gear
  145. Transmission Leaking
  146. Auto trans gurus? Question.
  147. D-Series vs B-Series Pressure Plate Thickness?
  148. D series Tranny Identification
  149. odd squeal in ITR transmission
  150. gsr trans - not engaging
  151. Transmission And Gearbox Oil Question?
  152. no third gear
  153. Weird knocking under braking (brakes? clutch? axles?)
  154. LSD Install?
  155. ITR tranny .. stuck in gear
  156. transmission fluid
  157. Changing Diff bearings?
  158. Rebuilding a non stock tranny
  159. Reputable tranny repair shop in/around Long Island?
  160. wierd issue with JDM LSD
  161. spool fwd diff
  162. can GM Syncromesh FM make tranny whine?
  163. stage 3 clutch, stock motor help
  164. HELP! 2005 Civic Ex 5spd, stuck in 4th gear!
  165. for those with a 4.9 FD...
  166. ls tranny with light weight fly wheel on gsr?
  167. Clearance on LSD
  168. LS Tranny with a B16 final?
  169. WTF...can't shift
  170. shift fork question(looked in the sticky)
  171. blind hole bearing puller
  172. Loose shifter!!
  173. what causes a transmission shifter to lean to the left.
  174. utch pedal no preasure
  175. GSR LSD Swap into B16 Questions
  176. What causes the terrible oem clutch feel?
  177. Odd Vibration when accelerating
  178. ClutchNet?
  179. Differential bearings??
  180. 91 Civic 1.5 Liter 5 Speed Clutch
  181. Tranny problem, Can't shift into any gears
  182. transmission problem
  183. d16y7 transmission question
  184. Where to purchase 3.077 1st gear?
  185. Binding gears?
  186. D16 tranny bolts can i use them to bolt a GSR TRANNY TO A LS BLOCK
  187. stupid question
  188. clutch pedal not releasing
  189. Transmission Issue
  190. Resurfacing Flywheel?
  191. Leaking oil from Shift linkage hole??
  192. ATS 4.928 final drive in GSR tranny
  193. tight fit with axle
  194. Unsprung(Rigid) Kevlar Clutch?
  195. torque converter + speed sensor both bad?
  196. Clutch grab point during break in
  197. worn synchros
  198. blew the motor .tranny related. Got few questions. please help.
  199. bad clutch?? need help
  200. safe to hot tank transmission casing?
  201. B16 Tranny or LS
  202. Car on, shift into gears with out clutch pressed in
  203. wont shift
  204. Adjustment for Extension Rod?
  205. What Transmission? VIN number inside
  206. Tranny Mount Issue
  207. 4.78 FD and a Turbo LS???
  208. Hydro B16 FD gear set worth anything?
  209. Quaife/Mfactory lsd- Torque Bias
  210. tl type s diff
  211. Axle Well Not Stay In..HELP
  212. broken axle LSD
  213. help identify my P20-A000 d series tranny
  214. how do i identify what d series tranny i have?
  215. m2b4 gear set
  216. M2S4 Carnage!!
  217. trans axle seal???
  218. any ideas anybody..please help
  219. Hydro 5th in a Y1 cable trans?
  220. GSR Tranny, Wont go into any gear.
  221. Broken third gear on countershaft...where to buy synchros and replacement gears?
  222. b16 1-4th gear? ls 5th?
  223. Buying OEM Axles...?
  224. Will an obx gsr lsd fit into a cable ls transmission?
  225. EG w/ Lightened Flywheel, Stall at stand still w/ AC on
  226. Tranny problem!!!
  227. EG aouto to manual HELP.
  228. MFactory's 3.070 1st gear -- Impressions?
  229. Cleaning Tranny: Carb Cleaner VS Brake Cleaner?
  230. Do not know what happened
  231. problem with keeping my axle in
  232. CV joints stopped clicking
  233. Transmission Double Engagement
  234. Gsr tranny help
  235. em1's tranny has notchy shifting
  236. Exedy clutch kits
  237. Help With GSR "Shift Selector"
  238. tranny swap what do i need
  239. hydro LSD in cable trans?
  240. Tapered differential bearings to ball bearings - which shims to use?
  241. Manual shifting AT, 2000 v6 accord
  242. close ratio gearing
  243. will a 96 auto tranny work in a 94?
  244. Welded diff
  245. New exedy clutch
  246. Problem's with Tranny. 99 Gsr
  247. tranny leak Problem!
  248. trouble removing transmission EM1
  249. Question regarding custom gear ratios...
  250. Clutch Pressure Plate wont clear tranny?
