- Blew my B16 non LSD Diff?
- snap ring, counter shaft bearing clip, part #/number
- putting back tranny
- Exedy Stg2 for a B20v
- Automatic B18C1 swap? Please help
- honda prelude tranny/shift linkage?!?!
- Help me find this damn gasket.
- need help choosing axles
- LS tranny wont go 5 or R
- DSS 2.9 longer than OEM?
- USDM ITR S80 Trans case bolts!! HELP!
- Speedo Moves...Car Doesn't Please help
- Legend Auto to Manual Swap
- gsr trans 4.7 fd whine problems
- Which sensor is that?
- Clutch: is it bad? (I have searched)
- auto trans gearing
- How to build a stock tranny for high hp???
- Mainshaft Lock Ring Position
- Exedy Twin Throwout bearing
- Killing one Clutch Master Cylinder at a time, help please? :(
- Kragen Clutch Slave Cylinder Doesn't Fit!?
- Final Drive Install Gone Wrong...Input needed!
- auto tranny problems
- Rebuilding 02 civic transmission
- Drive shaft axles level 2.9. RSX
- Reliable Trans shop IN MD VA DC
- Accord Transmission Swap
- Another ITR LSD into b16 question
- Competition Clutch Vs. Exedy (Which Is Better)
- Differential Tolerances
- lsd gsr trans multiple problems??
- clutch question
- Clutch kit recommendations for my 94 EG Hatch?
- Where to buy k20a 6speed trans?
- Tranny seal leaking into clutch assembly
- diff. bearing going bad?
- gear swapping
- 0.875 5th gear dilemma
- EG 5 Speed Conversion
- bled the slave, sometimes pressure on pedal sometimes not???
- Tranny problems-car turns on but wont go into gear
- Cracked 4.4 Final Drive pix.
- transmission installation
- How to tell if my b series tranny is ls or b16
- Transmission SWAP QUESTION!!
- Trans rebuild questions!
- What trans fluid do you use/recommend?
- H-series Trannys always go bad??
- Where can i find a transmission for my D15B7?
- Car won't go into gear!!
- LOUD humming sound in front of car
- where goes this thrust washer?
- act 6 puck HC5-SPG6????/
- HELP!! clutch slipping
- What final drive can I use in my ITR tranny
- help choosing diff for S1 trans
- h22 m2b4 tranny, reverse issues
- USDM Tranny capacity
- cv axle ? please help
- Gear Box Experts
- Can I use a honda Diff for an off road buggy project?
- Does anyone have a parts list for a simple B16 transmission seal refresh?
- what aftermarket lsd is good?
- b-series tranny compatability...
- 1st gear pop out, NOT THE TYPICAL!!!
- decelerating noise?
- Which Clutch???
- Clutch problems after acceleration
- h22t switching to h2b
- EX Transmission Rebuild with HX Synchros
- LS trans diff wobble aftermath *pics*
- Axle-Midshaft question; is this normal?
- Transmission won't align
- Tranny Or Engine
- VSS - 97 GSR to CTR
- WONT SHIFT !!! please help
- Quaife LSD Warranty's Help????
- Destroyed reverse.. Need advice..
- b-series tranny whining?
- Name That LSD
- MFactory 3.070 1st gear ('98) Help!
- Need help...axle stuck?
- fidanza flywheel and a/c...
- b16/gsr synchro clearance and tolerance
- Shift linkage seal leak - please help diagnose!
- Clutch experts please chime in!
- Throwout bearing question
- clutch type lsd...what oil
- wavetrac lsd break in
- paddle shifting question
- Popping out of gear cause?
- jdm dc5 gearbox vs usdm type s gearbox
- Smooth Engaging Street Clutch for Daily Driver?
- Tranny ran w/ no fluid!
- itr tranny problems.. need help!!
- what clutch should i buy?
- Take a look at my pressure plate and tell me if this is OK
- b16 tranny bad diff can i use a LS diff?
- ats lsd speedo gear, what color?
- ls tranny with si gears?
- are my sychros going bad, or what is it?
- GSR Transmission question.
- C-Clip Causing Binding
- unsprung clutch good ? or bad?
- B18 LS trans problem
- Can B16 cable tranny internals swap to a ls hyrdo case
- New LSD Option? Megabite LSD
- ----== 10 BOLT LSD PATERN??? ==-----
- Did a little investigating in my transmission last night
- Need M10x1.0 Bolts for Differential
- WHAT AXLES TO GO WITH (3 choices) HELP?
- source for JDM ITR 1st gear distance collar and needle bearing only?
- need help cant taking off bearings
- HELP ME..... MY LSD BROKE LOOK!!!!
- 96 GSR Trans problem!! HelP!
- question reguarding cv axles and trans question
- unknown condition of tranny....
- gsr and b16 flywheels
- comp stage 2 and 12lb fly, need sum advice
- Transmission Rattle Driving Me Nuts! O____o
- M2A4/issue/pulled please help
- LS 5th gear mainshaft?
- bad axle or diff?
- Exedy clutch questions
- s1 tranny
- update-now 5 different B series OEM LSDs
- Clutch/Shifting issues HELP please
- Can OEM LSD 's wear out?
- car dies when in gear
- shift linkage question
- Tranny Whine
- comp. clutch stage 4 chatter/shudder
- A F22B1 - F22B2 transmission swap?
- 3rd gear doesnt want to go! some feedback please.
- Honda B Series trans bearings
- replacing clutch only
- d series rebuilt ping noise
- Trans help!!!!
- help needed hard shifting which fluid
- JDM B16A auto trans OBD1 vs OBD2?
- b16 tranny problem
- LS transmission 5th gear prob
- LSD for LS Tranny
- Removing Crank Shaft bolt and pulley
- possible shifter linkage issue.
- TRANS NOOB "Q"
- Do I need to swap my linkage?
- need to know what kinda tranny is this
- Rebuilt Transmission won't shift right
- posible clutch problem?
- GM synchomesh!
- Do I need to upgrade when using a twin disc clutch?
- Transmission Rebuild NJ
- Clutch change and driver's side axle.
- Helical or Metal Plate LSD?
- Will my old Type R clutch fit?
- help with LSD & Ratios query?
- JDM B16 Trans Clutch tool and clutch qestions
- Quaife LSD
- GSR TRANNY (HELP)
- straight cut gear set????
- b series ring gear question
- Cable b16 y1 lsd fit in a cable ls trans?
- 2nd gr always pops out, is there a temp. fix?
- my B motor and its stock A1 tranny..
- Clutch suggestions for gsr
- A/T Question
- Weird transmission problem take a look please.
- big d series tranny probs
- car fluid question
- VSS repair - Help needed.
- 700-800whp on a cable trans... Clutch recommendations?
- B16 wont go in reverse
- jdm auto trans and usdm auto trans the same?
- Is my GSR Tranny going out?
- k20 tranny code
- Need help picking a clutch
- 99 SI trans S4C issue
- Best clutch for the money
- Need help with S9B
- Hydro to cable.. How hard would it be to swap
- OEM or OEM REPLACEMENT CLUTCH
- Rebuilding tranny
- Titanium Axles?
- Transmission slipping and jerky
- No pressure on cable clutch
- trans fluid & lsd additive
- CHANGING TRANNY FLUID HELP.
- del sol tranny HELP
- any expierience with Synchrotech Transmissions Inc final drives?
- Heavy Clutch Pedal
- 1991 CRX 1st to 2nd problem
- Type R transmission wont mount!
- Getting LSD
- 98 ex shifting hard
- 3rd gear for B16 J1 cable trans.
- 8.5LB Flywheel weight
- what tranny is this
- Odd problems with b16a tranny
- Help in choosing the correct gear ratio for 1/4 mile..
- f20 auto trans need help badly
- Competition clutch stage 2 question
- tranny leak...maybe wrong half shaft?
- gsr tranny problems
- B16 Tranny Problem?!!!!
- How to check if my speed sensor is damaged?
- 1990 Civic cable clutch not fully engaging?
- What Flywheel Should I Use
- Noise From tranny area while driving
- help identify these clutch components
- throwout bearing differences in hydraulic trannies
- lsd fluid
- Clutch pedal won't retract, remains depressed. Any Ideas?
- MASSIVE Clutch Problem! Need help please.
- Cable tranny conversion?
- Snap Ring on mainshaft part
- Clutch friction point changing
- competition clutch stage 4 problems
- Braided Clutch Lines
- Longest final drive available?
- h22 flywheel
- difference between 10 bolt and 14 bolt lsd
- FD installed, trans will not turn???
- parts store axles
- Need help getting the casing off D-sieres Tranny
- GSR trouble going into gear...some times
- Case wont close (countershaft to blame?)
- K20 6 speed Synchro Pic....need some parts
- Which differential bearings?
- b16 2nd gear grind
- need a liberty or a ppg transmission soon
- l.s.d rebuild kit
- honda trans adpt plate for d16z6 to LS
- what is S4C and stamped R4 LSD?
- Zc and Civic 95 transmission?
- S2k Synchromesh and Dog box Trans (Where to find more info?)
- Losing pedal pressure in high RPM's
- parts quaife install
- help: auto to manual
- S4C:diff from CTR to JDM B16a sec Gen tranny
- transmission shop help
- Quartermaster Twin Disk
- Clutch wont go into gear
- Where to find ring gear bolt (jdm s80)?
- Cable YS1 Trans Problem HELP!!!
- mfactory or obx lsd?
- Cable LS trans possibly broken
