- Axle doesn't line up with mid shaft right
- Short shifter slop
- Synchrotech Pro series Carbon Synchros?
- gsr trans 2nd gear problem
- twin disk help Grinding and clicking
- 93 trans swap...
- B series front shifter bushing dimensions.
- 04 Honda Accord v6 auto( need some advice)
- B Series Tranny Doesn't Like 1st Gear When Cold
- d15b7 axles to short
- D16Y8 with 4.7 FD, clutch upgrade?
- D16A Transmission swap HELP!
- Clicking when barely moving forward?
- 99 civic ex CTV d16y8
- LSD Selection
- 98 Type R, possible whining noise from transmission
- Stronger H/F Trans Options with Long Gears?
- Lsd id help
- Intermediate shaft and drive shaft fully engagement ?
- How to bleed hydraulic clutch by yourself
- Shift boot and skunk knob
- Blew my clutch in less than a day???
- S80 synchro hub question
- JDM ITR trans maintenance and compatibility questions
- Accord short shifter install obstacle??
- how to repair 3rd gear grind
- 92-95 Transmission Help - Final Drive - Mista Bone
- 2001 civic ex bad tranny help
- identify jdm gsr transmission
- Exedy Twin Disc on S80 Tranny Help??
- Transmission blew!!
- ITR LSD into Y80 GS-R casing.
- clutch fork retainer clip correct placement?
- Buying LSD Transmission - what to look for?
- YS1 LSD trans price
- 1988 Honda Accord LX Sedan TRANNY HELP PLEASE
- Looking for recommendations where to buy rack and pinion.
- B16a2 transmission problem
- serious trans help needed
- Auto Trans Parts Crossover
- cv outer joint stiff
- Won't go in gear while car is running.
- 2001 Odyssey P0720 code and trans issues
- K20 with h22 tranny
- Swap Accord trans to Odyssey?
- 01 prelude transmission noise please help
- Anyone running a mfactory metal plate LSD? How often do they need to be serviced?
- F20b swap
- Best transmission for my B20B DA?
- 94 Prelude clutch issue.
- Is taking off with a lightweight flywheel like taking off in 2nd gear?
- B16 tranny bell housing bolt ID
- Looking for a Y1 2.052 2nd gear.
- 94 honda civic vtec 4door
- B16 sequential gearbox
- Ys1 B series Issue
- Differential or Axles (Video inside!)
- Where to find final drive ratios on manual trannys..
- Rebuilt Trans Not Moving In Neutral
- Need help :(
- Stronger Cv joints
- New exedy stage 1 clutch kit vibration
- 01 Accord P0730 & P0780
- Aftermarket B series looong 5th gear
- Burning clutch smell
- Compatable transmissions for an 99 accord
- Lost All My Gears
- 02 crv new clutch stalls in neutral wont drive
- Not Honda but close.
- B/H gear interchangeability?
- 2006 Honda CR-V Clutch Chatter
- Transmission crunch
- Dropped bolt into trans while trans on car
- Turning a hydro trans onto cable operated?
- B7WA M7WA differences
- anyone ever move their shifter "back more"?
- Does H23 M2S4 Tranny have an LSD?
- gearbox giving problems
- Honda civic coupe 95
- Type R transmission; 3rd gear engagement issue
- Transmission Oil?
- Trans flush after 178k miles?
- Can an Acura trans go into an 04 Accord Coupe
- where can i found Final gear ratios 1-5 gear ratios
- torque converter, please help
- Differential & Final Drive Ring Gear questions
- Carbon synchros normal? (pics)
- Pneumatic Paddle shifter for any H pattern gearbox
- 1993 Prelude si 4 speed automatic question
- Car will go into correct gear but wont pull
- Auto Tranny : S4XA B18 integra vs S4XA B16A EK4
- m2u4 gut into h2a5
- Transmission shifts hard
- T2T4 LSD / H22 LSD
- YS1 Diff in a S80
- Shifter button stuck
- B16a/y21 Top Speed
- 217whp k20a2 best drivetrain??
- Strong transmission ideas?
- 89 si tranny into an 89 hf crx
- No neutral
- Dogbox Rough engagement
- upgrade clutch for LSD ?
- RDX transmission flush
- Replace or rebuild
- --CLOSED--
- Possible new idea for transmission oil cooler pump?
- Rsx awd
- Sandrail motor swap
- LS Transmission Reverse Issue
- B16a y1 cable transmission slipping issues
- Y1 5th gear pop out
- I need help with buying axles and ball joints!
- 2007 Accord LX Auto - question about axle meeting transmission
- Flywheel for my Civic EK4 VTI
- 99 honda civic ex shift stuck automatic
- 2003 Civic D17 Final Drive
- wtb : brackets for b series for my 99 si
- Shift Linkage Lengths Among Civics
- Burnout noise
- B16 cable tranny twin disc competition problems!!
- Helpppppp!
- Final Drive Wear
- b18b hydro 4.4 fd
- transmission builders
- Invincible Aluminum/Tin/Steel CV Axle Boots?
- Transmission sounds and jerking (2013 Civic SI coupe)
- SOHC clutch kit in DOHC engine
- Broken Carbon Coated Synchro?
- ANOTHER Accord transmission question
- Auto transmission auto shift feature
- Bad clutch?
- Loose Clutch Spring Rattle????
- Trouble Fitting D15 Tranny onto D16 Block
- Clutch for 300whp all motor, B-Series.
- NEW CLUTCH INSTALLED ... first gear shakes when engaging
- stage 2 MITSUKO CLUTCH in 99 4dr civic ex kept stock flywheel.now shakes on take off?
- Cause of damaged MT?
- Transmission noise
- 05 acura rsx auto trans slipping
- axle help b18a1
- 95 Del Sol Si Transmission question
- Dropping a Transmission
- I want to find an LSD tranny
- Lsd Tranny ? Need Help Not Sure
- M2B4 stuck/hard to get in gear (pics inside)
- P0741 code on Honda Accord 2006 V6 transmission
- Automatic gear stuck in drive
- 98 gsr wont go into any gear!!
- JDM integra clutch master cylinder
- Hard reverse with a 5 speed forced the car to go forward?!!!
- Change transmission to manual
- S9B Torsen LSD whp limit
- Gsr transmission 1st gear problem
- '94 Auto Del Sol Sometimes Won't Shift out of 2nd
- 99 accord transmission issues
- Is my tranny near death?
- Failing clutch?
- S80 problems
- 2002 Honda Civic
- Quaife LSD in Y1 tranny compatible with YS1?
- Mild EK build CLUTCH OPINION
- Very loud Screeching noise linked to clutch pedal
- rwd conversions
- Blown tranny? CV joints?!?! NEED HELP!
- 93 LS cable trans/clutch pedal issues
- 2001 Acura CL Transmission
- B series cable 3-4 shifter fork
- 92 civic recent transmission n clutch prob
- No tension in clutch cable
- New Engine, new transmission, new ECU same problem
- 01 civic hard to shift when hot
- 2006 honda civic si clutch
- 9th gen final drive
- Slight leak / drip out of transmission
- axle is a bit loose In the trans....
- locked out if reverse and car wont move after clutch install. Help please
- Manual Transmission Identification
- Good place to buy clutches
- Rdx max torque
- Reverse going in but not reversing???
- S4MA automatic transmission-oil type?
- Selecting gears problem b series
- High HP solution for K Series
- Help
- 3500 rpm Driving load vibration and trouble shifting advice need!
- identifying LS transmission
- J1 transmission Differential Sliding...
- 95 civic speedometer not working
- Transmission hose
- Ls tranny vs gsr with ls 5th and final gear
- Best Transmission for D16Y7
- Clutch replacement
- Clutch petal holds no pressure!
- Possible transmission problem? need some advice
- 91 accord mainshaft and countershaft sensors
- help 90 crx si swapping s20 hydro tranny
- loud bang from front.
- Should I Worry that "Dry" Transmission isn't Shifting?
- Can't get Type R trans back together
- S80 Tapered bearing?
- 97 civic & 95 Accord
- JDM ys1 transaxle?
- Exedy / Fidanza
- transmission problems plz help
- What's the best tranny fluid to use??
- Main shaft problem, too long?
- clutch disengagement issue
- del Sol B-Series shift linkage
- Take a look and tell me whats going on 96 ITR Tranny
- B16b jdm civic type r transmission oil
- Flow control valve in street car
- Help! Need to rebuild tranny asap need advise
- ITR Trans with kaaz lsd ?
- Risk of burn if draining ATF hot?
- help ! no pressure at clutch pedal
- M2B4 LSD - which manual from prelude?
- dumb clutch question
- custom Trans build?
- breaking axles
- Transmission stuck in park
- 1998 Cr-v transmission.
- B20 eg speed sensor problem
- flywheel choice?
- 2002 Odyssey EX trans question
- y1 lsd b16a tranny question.
- Transmission damage from axle failure?
- New GM Syncromesh Friction Modified MTF Part #
- 99 odyssey overfilled tranny fluid won't go into any gears
- ITR 5th gear - identifying marks on teeth?
- 95 civic transmission/no reverse at all
- 94 civic ex trans noise
- Need help: ITR tranny diff might be broken?
- clutch hydraulic issue?
- what will cause a 5th gear pop out and but no grinds
- LSD Bearings being destroyed ??
- Need help identifying Shifter linkage
- Weak acceleration and shifting problems in '12 Civic
- help locknut on countershaft 5 speed tranny rebuild
- New oem b16b diff?!
- Integra GSR 95 B18C1
- Shifter not returning to center position after transmission rebuild
- 3G TL synchro part numbers question
- Skunk2 clutch
- . 96 honda accord. ex transmission
- RSX transmission grinds into every gear
- HELPPPPP!!! 97 honda civic. shaking while accelerating!
- Sloppy shifter in gear
