will this burn obd0 chips?
Old Dec 30, 2009 | 03:40 PM
blasterman87's Avatar
Default will this burn obd0 chips?
im gonna take a wack at tunning my obd0 b16 (pr3) for boost and i need to know if this http://cgi.ebay.com/ebaymotors/MOATE...Q5fAccessories can be used along with turboedit or uberdata?? and thats all ill need except a wideband and some chips/socket right?
Old Dec 30, 2009 | 03:55 PM
HRTuning's Avatar
Default Re: will this burn obd0 chips?
The Burn2 is more than capable of burning what you need. There's some chips included. All you need is a socket installed. A wideband is always a good choice when tuning.
Old Dec 31, 2009 | 12:46 PM
thank you, thats what i needed to know before i baught it. what is a good wideband to get? and should i get a a/f gauge that stays in my car after tunning?
Old Dec 31, 2009 | 01:10 PM
oh and what is a ostrich and do i need one? from what i understand it allows you to tune on the fly in real time?
Old Dec 31, 2009 | 02:05 PM
HRTuning's Avatar
If the software supports Ostrich you'll be able to do real-time tuning.
LC-1 is a good wideband, so are the PLX units.
Old Dec 31, 2009 | 06:06 PM
now ive been reading up on turboedit. and i dont think it supports boost with the pr3 ecu... now what?
Old Jan 1, 2010 | 11:25 AM
anyone?
Old Jan 1, 2010 | 11:30 AM
HRTuning's Avatar
There is an editor for OBD0 that does boost on PR3... You'll have to look.
If you don't find that as a good option for your setup, get an OBD1 conversion harness and use something way better, like NepTune RTP.
Old Jan 1, 2010 | 03:29 PM
mar778c's Avatar
Community Builder
Community Influencer
BRE will run a OBD-0 boosted engine. It was made for PR3 and PW0 ecus. It has real time programming and datalogging capability. I have used the ostrich and burn1 with a lot of success. One of the major problems with boosted motors and BRE is running larger than stock injectors. Alot of the features to control fueling are simply not there. Injector scaling is available but tip-in, cranking fuel, etc are not. Cold cranks with 680s on a B16 are not very fun.
I recently switched to OBD-1. Neptune was used to tune my car. It is a 1.8L making 225 whp. I switched because we ran out of injector (240s) on the dyno. How well a car runs is dependent on a alot of things but two of the most important are the tuners ability and the capability of the tuning software. I can easily making the switch, running Neptune, and maybe my tuner if you are within the NY, PA, MD area.
Old Jan 1, 2010 | 03:39 PM
i downloaded bre vers 2.2, but i cant get anything to open, all of the files are empty eg:stock pr3 maps, pwo maps..everything except the readme files. ?
Old Jan 1, 2010 | 04:06 PM
mar778c's Avatar
Community Builder
Use this link
http://www.ef-honda.com/ben/tmp/obd0testing.zip
Old Jan 1, 2010 | 04:41 PM
thats whare i got it. i think i dont have the correct version of a certan windows program to open it. i read that in the bre faq on pgmfi.org
Old Jan 1, 2010 | 05:33 PM
i downloaded it again. still all files are empty except a few with just random numbers..
Old Jan 3, 2010 | 06:48 AM
mtber's Avatar
Try looking for a link on http://forum.pgmfi.org
My suggestion would be to upgrade to obd1
Rukusmasta2
Engine Management and Tuning
May 8, 2008 07:18 AM
allnaturalb16
May 5, 2007 11:01 AM
EFin' Kyle
Sep 26, 2004 05:58 PM
