MAP sensor :/
Old Jan 3, 2010 | 01:14 PM
92SikHatchBak's Avatar
Icon2 MAP sensor :/
So I had my MAP sensor go bad on me last week, seemed a little sluggish, vtec powerband was absent and it threw a code. Got home pulled the cover off to expose the ECU, and it threw a code 3 or MAP sensor code. Got under the hood and removed the sensor and where there should be a gasket the previous owner siliconed it to the TB.. (Woo, now either I get to use a dremol on it or have it machined..) Can't believe it.. Anyway, since the previous owner didn't even bother getting a gasket for the sensor, I'm starting to wonder if he even used the right map sensor (I've found a few other things that were "jimmy-rigged" and am not too happy about)...
Anyway, my question is which map sensor do I NEED, ill have to look at the code of the one that's on it right now, ran fine with no problems before, no codes, crossover was good etc, but I wanna make sure I'm using the RIGHT MAP sensor.
Not really sure what info is needed to figure out which map sensor is needed but I am running an LS-Vtec setup, B18B bottom end with a Type R head, if I need to provide more info please let me know!
Any and all info would be greatly appreciated!
Thanks H-T!
Steve
Old Jan 3, 2010 | 03:33 PM
Default Re: MAP sensor :/
Bump for answer's Honda-Tech!
Old Jan 4, 2010 | 04:46 PM
mtber's Avatar
Any Fseries/Dseries/Bseries obd1/obd2 map sensor will work just fine. They all look the same & work off the same scalar.
Old Jan 5, 2010 | 04:24 PM
bemanuel's Avatar
Exactly just go to a salvage yard and find a MAP sensor. Also, there are probably many up here for sale that are used from people with turbo cars, actually I might have one laying around somewhere.
Also, why not just use a razorblade to scrape that silicon off, I really don't see the reason why you would need it machined.
Old Jan 6, 2010 | 09:38 PM
Well the idiot seemed to have siliconed it, and then pushed it down with the (male end going into the female... best way I can describe that little hose thing..)
There was silicon in the TB from where it had been put in
But thankfully, we got it taken care of today
Bought a sensor off a GSR, got the TB machined, installed and she back on the road
Thanks again H-T!
FSS13foxtrot
Jan 20, 2008 06:23 AM
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
mattmw88
Apr 11, 2005 05:46 PM
