E85 Help...
Old Jan 8, 2010 | 07:27 PM
shainesboostin's Avatar
Default E85 Help...
OK, So, got a b18c1 with 12:5 compression, and A set of BIG cams. The car has been running 93 octane, but where I live I can no longer get it. So, I want to convert to E85, however, I dont know what size injectors I need. I believe you need 30% bigger than stock, but I dont know what stock are?
Any help, or opinions are apppreciated!
Old Jan 8, 2010 | 07:53 PM
mtber's Avatar
Default Re: E85 Help...
Some 440cc injectors should work just fine.
We stock precision 440cc injectors which seem to be the most bang for the buck.
Old Jan 8, 2010 | 08:41 PM
MrDomino's Avatar
You may be able to use DSM Blue top (450cc) injectors provided they can withstand the E85 (check on this).
Old Jan 8, 2010 | 08:45 PM
q16racer's Avatar
i really liked the precision injectors. But if i had the money, i would run injector dynamics.
________
Z4
Old Jan 14, 2010 | 10:37 AM
92TypeR's Avatar
FSAE
ID 725's for N/A E85.
Your pump will most likely need something that can support 250+ Lph.
Old Jan 14, 2010 | 10:48 AM
MAperformance's Avatar
I personally would run something in the 625cc range. The new Fuel injector clinics work great!
https://honda-tech.com/forums/performance-45/dyno-street-proven-new-high-impedance-fuel-injector-clinic-injectors-2609903/
1998GsRIntegra
45
Nov 3, 2010 08:00 PM
shainesboostin
Jan 8, 2010 07:52 PM
hondavtecsi1
Mar 19, 2009 10:32 PM
hip_hop_s0ulchild
Oct 26, 2005 05:47 AM
k_bster24
Apr 2, 2004 06:50 PM
