Chip question
Old Jan 20, 2010 | 04:01 PM
95BoostedEJ1's Avatar
Default Chip question
not sure if this is the wrong section to post this but mods can move it to the right spot..i bought a moates burn2 chip burner and i tried putting a base map to a chip i had in my car that already had a stock map on it and i tried to put a tune on it after putting it into my car with DSM 450's the car started for about 15seconds then died and was idling rough so i shut it off and tried to burn another tune to it but wont start..on the flash and burn program i hit erase chip says erased but when i click on blank check it says its not blank so my question is..could my chip be bad or am i missing somthing when i burn the tune?
Old Jan 20, 2010 | 04:51 PM
93turbo16's Avatar
Default Re: Chip question
What chip are you using?
Are you using the correct offsets for the chip if it is a 512kb chip?
Old Jan 20, 2010 | 05:36 PM
nebraskaimport's Avatar
on those injectors did you use resistors on them that could cause your problem
Old Jan 20, 2010 | 05:42 PM
its the 27FS512
yes i have a resistor box hooked up
Old Jan 20, 2010 | 06:37 PM
93turbo16's Avatar
Originally Posted by 95BoostedEJ1
its the 27FS512
Again.. what offsets are you using?
Old Jan 20, 2010 | 06:40 PM
what do ya mean?? new to the whole burn to flash stuff
Old Jan 20, 2010 | 07:03 PM
i dont think i fried the ecu cause the fuel pump primes..i just think the chip isnt gettin the tune im tryin to burn onto it
Old Jan 20, 2010 | 07:09 PM
93turbo16's Avatar
Exactly. If you are using an SST 27SF512 chip then you are not burning it properly. Which is what I was trying to get at.
Read this...
http://www.moates.net/documentation....entation_id=75
Basically you need to change the Chip Address -> Start Address to 0080000 and it should be good to go.
Old Jan 20, 2010 | 07:42 PM
oh well that makes sense haha..thanks man
Old Jan 21, 2010 | 01:33 PM
turbodcxbro's Avatar
The moates burn 2 device automatically sets the correct starting address for the 27SF512 chip...
Old Jan 21, 2010 | 02:42 PM
well why wont it erase the chip?
Old Jan 21, 2010 | 02:52 PM
i keep trying to erase the chip..it says it erased successful but when i check to see if its blank..says chip not blank
Old Jan 21, 2010 | 07:31 PM
93turbo16's Avatar
That is news to me, but then again I have been using the same burner since I purchased this one in 03-04.
I am pretty sure the start address is user definable so a user can put 2 rom files on a 512 chip.
If it set the starting address automatically it would re-write the first bin file when you went to burn the second onto the chip.
Also as far as the blank check goes.. there have been times that the blank check has come up "not blank" after an erase. But if you burn the file onto the chip it takes it just fine.
I honestly never do a blank check anymore.
Old Jan 21, 2010 | 07:32 PM
tried a different chip but no luck...i hit erase says erased but when i check for blank says "chip NOT blank"
Old Jan 21, 2010 | 08:01 PM
93turbo16's Avatar
Again.. I would not worry about it saying "chip not blank"
Just hit erase.. the program the chip with the new file using the offsets posted in the link above. Then give the chip a shot in the car.
Old Jan 21, 2010 | 08:06 PM
well on that link u posted it says the 27sf512 have to be erased before u can put another tune on it..cant write over it..i tried a different chip and the car would run but ran REALLY rich..lots of smoke but was idling but idling very rough and wouldnt rev good..lots of popping and bubbling like its gettin flooded really bad..
Old Jan 21, 2010 | 08:12 PM
93turbo16's Avatar
I sent you a request on MSN. Maybe I can help you out through there.
Old Jan 22, 2010 | 01:15 PM
problem fixed..i was putting the chip in the burner wrong..i thought that when the light came on it meant it was in right not that it was in wrong haha
Old Jan 23, 2010 | 02:15 PM
93turbo16's Avatar
What a simple solution!
It is always the most obvious things when it comes to stuff like this, that gets people.
Old Jan 23, 2010 | 06:55 PM
yup lol
toony
Engine Management and Tuning
Apr 4, 2021 12:55 AM
lkailburn
Dec 31, 2015 03:03 PM
butter99
Jul 20, 2010 05:20 PM
Honda4life777
Jul 11, 2009 09:39 PM
JayDM_lsvtec
Apr 7, 2005 03:40 PM
