Ignition break up
Old Jan 30, 2010 | 07:13 AM
K20EF8Dx's Avatar
Default Ignition break up
ok last summer i put my integra on the rollers since i switched over to S300. its basicly a stock LS i was doing some tesint on before i go the LS/Vtec route. problem is after 5500rpm it started breaking up. Hondata says you need resistor plugs i pulled mine out and they were BKR6. i even tried adjusting the gap from.044 to .035 (turbo gaps) and no changes. was told possible issue with valve adjustment ? anyone have some more information?
I attached a pic of my graph. ill have to also look over my logs.
Old Jan 31, 2010 | 06:37 AM
K20EF8Dx's Avatar
Default Re: Ignition break up
TTT
Old Jan 31, 2010 | 10:14 AM
mtber's Avatar
What ignition system do you have ?
Try a stock integra distributor (OEM, no aftermarket autozone crap).
Old Jan 31, 2010 | 12:07 PM
jdm inc's Avatar
x2
Old Jan 31, 2010 | 04:26 PM
K20EF8Dx's Avatar
its an oem distributor with oem ignitor and coil (to my knowledge). NGK plug wires.
Old Jan 31, 2010 | 07:49 PM
jdm602's Avatar
can you feel it or hear it breaking up? might have had a bad pickup reading.
Old Jan 31, 2010 | 09:50 PM
mtber's Avatar
Try another distributor assembly & wires...
Old Feb 1, 2010 | 10:15 AM
K20EF8Dx's Avatar
i was hoping but you can see the tach cutting out in the car. bounces back and fourth around 6k.
ill try another distributor plugs and wires. migth go down to honda and buy both new ignitor and coil. i guess ill tear it apart and look to see if any honda part numbers are on them or if they are aftermarket.
Old Feb 1, 2010 | 10:17 AM
jdm inc's Avatar
goodluck let us know.
Old Feb 1, 2010 | 06:29 PM
MONSTERek4's Avatar
gap the plugs at .25 then give it a world
Old Feb 2, 2010 | 04:45 AM
K20EF8Dx's Avatar
thats a very small gap for a NA set up. i changed from .044 to .035 to .030 and nothing changed it was the same RPM everytime.
Old Feb 2, 2010 | 06:18 AM
jdm602's Avatar
why do you guys think its the plugs? he alread re-gapped and saw no change.
BKJJ77
17
Mar 11, 2012 12:14 PM
Max500
Engine Management and Tuning
Mar 16, 2011 05:11 PM
D16SohcVtec
May 10, 2009 11:06 AM
Kyle244R948
Jul 29, 2004 10:19 PM
badazzaccrd
Feb 12, 2004 05:59 AM
