checking check engine lite w jumper harness
Old Jan 14, 2010 | 04:53 PM
chippinpressure's Avatar
Default checking check engine lite w jumper harness
was wondering if anybody knows how to check my codes on the ecu .its a 97 civic obd2 with a jumper harness to obd1 ecu .i plug in the scanner but it doesnt let me read anything.scanner reads no communication.i know the tuner can check it but would like to check it my self any info is appreciated.
Old Jan 14, 2010 | 05:31 PM
HRTuning's Avatar
Default Re: checking check engine lite w jumper harness
You can't run an OBD2 scanner on an OBD1 ECU.
Jump the service connector under the dash by the ECU and the CEL will flash the codes.
Old Jan 14, 2010 | 05:47 PM
nebraskaimport's Avatar
your probably running a knock sensor code or a o 2
honda305
Jan 7, 2009 08:37 PM
boostedjdmdc2
Dec 17, 2007 07:32 AM
CeeJayy
Jul 27, 2007 07:48 PM
SCsol
Oct 7, 2005 05:35 AM
agratise
May 24, 2005 06:17 AM
