obd2a to obd1 Conversion Question??!!!!! Help!!!!
Old Dec 16, 2009 | 03:57 AM
irvings213's Avatar
Default obd2a to obd1 Conversion Question??!!!!! Help!!!!
i have a 97 gsr shell with a b20b. my question is what exactly do i need for the conversion?? Jumper harness, OBD1 ecu, does the ecu have to be for integra gsr or could i get any obd1 ecu?? what else do i need to change?Also any threads where it shows you how to do this Any help is greatly appreciated?!! thanks
Old Dec 16, 2009 | 04:28 AM
q.man06's Avatar
Default Re: obd2a to obd1 Conversion Question??!!!!! Help!!!!
Depends on what you plan on doing. I assume you plan on chipping the ecu with hondata or something similar. All you need is the jumper harness and any chipable obd1 ECU. If you want to keep your knock sensor functionality make sure you get a p72.
Also, if you're running a b20 vtec or plan to run one, chip an ecu that's paired with a stock vtec engine such as the p28/p72. The p06/pr4 ecu's will work fine, but will have no vtec function without modification.
Old Dec 16, 2009 | 04:47 PM
irvings213's Avatar
Thanks atleast there one person willing to help a rookie! well i got a b20b non vtec my car is all obd2 P75 ecu. Now i dont plan on chipping anything for performance at the moment but i was told that if i convert it would run better and clear my check engine light?? So all i need is that the obd1 p72 ecu? and the jumper harness?
Old Dec 16, 2009 | 06:29 PM
q.man06's Avatar
If you're running a b20b on a stock GSR ECU then that's probably why you are throwing a code. I would speculate it has to do with a knock (not sure if the b20b has one) and/or the vtec solenoid.
I have no idea what the stock ecu is for the b20. Do some searching around and see what you can find. If you want the car to run good without some major tuning work, then find the ecu that matches your motor.
Old Dec 16, 2009 | 06:34 PM
Blown90hatcH's Avatar
IF you are running the P72 gsr ecu on a stock setup B20, you will throw codes. You need to run the non-vtec ecu.
Old Dec 21, 2009 | 09:29 AM
jdm602's Avatar
you could use the b20b ecu if you found one. or do a obd2a to obd1 harness with a chipped obd1 ls ecu or p28 with ls/b20 map.
(760)doogie
Apr 3, 2008 03:41 PM
00garrettsi
Jul 19, 2007 05:10 PM
trinihonda
Dec 3, 2005 11:51 AM
2.2 teg
Oct 20, 2005 08:21 AM
StolenTeg
Apr 29, 2004 04:53 AM
