best timing light?
Old Dec 23, 2009 | 06:52 PM
1320Mikey's Avatar
Default best timing light?
I broke my light and I am in the market for a new one. Whats the best one out there that everyone uses?
Old Dec 23, 2009 | 09:19 PM
jdm inc's Avatar
Default Re: best timing light?
in for more info! bump!
Old Dec 23, 2009 | 09:24 PM
mtber's Avatar
This is the unit I use.
http://buy1.snapon.com/products/diag...e_mt2661ap.asp
Old Dec 24, 2009 | 09:35 PM
mistR.DA9's Avatar
New User
Originally Posted by mtber
I've used the same one also, works well for me.
Old Dec 25, 2009 | 05:55 AM
GhostAccord's Avatar
With a price tag of $399.99 I hope that you are planning on using this more than once or twice. I will agree that it is probably the best one out there.
Old Dec 25, 2009 | 05:50 PM
mtber's Avatar
If you are on a budget, you can look into Equus and Innova timing lights.
They both do the same job & are 1/4th the price.
Old Dec 26, 2009 | 11:09 AM
BuddhaSiR's Avatar
Matco MTL4186 is what i use.Tachometer, digital advance.
I have a cheaper one i bought at autozone. OTC i think. Works just as well. Could be for sale if you need one. Also has Tach and digital advance.
Old Dec 26, 2009 | 05:11 PM
TurboLSVtecTeg's Avatar
I have and use the Snap-On light frequently. Its an ok unit. Ive had to send it out to get repaired a few times. It seems the pick-up has issues at times and I also had an issue with the buttons not working. Its all fixed for now and working. But I would think for the money the electronics could be a little better and not so unstable. Its always good to have a cheap-o back-up timing light available. Unless when yours is out for repair or broken you can get a loaner like I did.
Old Dec 26, 2009 | 08:43 PM
FaceTuned's Avatar
craftsman works fine for me.
Old Dec 29, 2009 | 05:32 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i have the old school snap-on with the dial. It work"ed" well and now i think the bulb needs replacing. Not sure cause it just stopped working
fenix4o9
Apr 14, 2011 05:23 PM
dem0nk1d
Jan 10, 2011 04:24 AM
91crx but i heard vtec
Oct 20, 2003 06:19 PM
Evil DOHC
Sep 8, 2003 02:51 PM
