launch control always on? ectune
Old Dec 19, 2009 | 11:59 AM
known's Avatar
Default launch control always on? ectune
all of a sudden my car is in launch control in every gear if the throttle is floored?
rpms are reading, mph are reading, so any ideas?
ectune software
i messaged my tuner but wanted to see if i could find anything out on here .
no cel, if i give it half throttle it will let me go the whole rpm range past where launch control is set.
i didnt event want launch control, i guess i should have said something.
yes i have searched but have found nothing.
this just happened out of no where
edit: update, mph just stopped reading so must be vss im guessing. mph was reading fine but did another test drive and nothing so it must have a loose wire or something like that. I assume that is why launch control is staying on.
Old Dec 19, 2009 | 01:11 PM
HRTuning's Avatar
Default Re: launch control always on? ectune
You figured it out.
Old Dec 19, 2009 | 01:40 PM
known's Avatar
Yeah thanks, I wasn't sure what ectune was looking for, clutch tps etc. I believe 6-8 mph, I just bought a replacement sensor so when I install I will update so others know for sure. Weird though because I had mph readouts driving during problem.
update it was the vss sensor for anyone that searches someday for the same problem. it was intermittently failing thats why the mph still read but ecu didnt read it.
Old Dec 19, 2009 | 02:09 PM
HRTuning's Avatar
Yup, should be active below 6mph or so. It does not require a clutch input unless it was setup that way.
reyesb25
Engine Management and Tuning
Jun 9, 2013 07:01 PM
RyanPm
Jun 20, 2009 05:28 AM
ill fast
May 4, 2009 03:06 PM
vtek9
Apr 6, 2008 04:19 PM
fin781
Jul 23, 2007 08:46 PM
