Hondata S300 CEL code 13 Baro Sensor
Old Dec 16, 2009 | 06:59 AM
88h22_CRX's Avatar
Default Hondata S300 CEL code 13 Baro Sensor
I have the s300 hooked up to a H22 in a crx. The CEL code says its a 13, which is a barometric pressure sensor(?). WTF is that and how do I fix it. The haynes manual says that sensor is in the ECU. But with sensor being in the ecu does that mean that my S300 is bad? I can hook it up to smanager and read the code, car runs fine but it does just cut off randomally but I think tha thas to do with something else (cracked TPS plug).
And with the CEL on I can not make any adjustments to the ECU, ie rev limitor etc? Is that the ecu protecting itself because there is a code or am I missing something?
I live in 29 Palms and the nearest tuner is like 2 hrs or so away.
Thanks for any info given!
Old Dec 16, 2009 | 07:06 AM
HRTuning's Avatar
Default Re: Hondata S300 CEL code 13 Baro Sensor
It's a sensor, not your s300.
Disable the atmospheric pressure sensor in the software.
Old Dec 16, 2009 | 08:22 AM
88h22_CRX's Avatar
Thanx! I'll give it a shot when I get off work. I'm guessing it will be in the selectable tabs right? I have only hooked it up once to my laptop and that was a long time ago to get the code originally. But if I remember correctly I didn't see that as an option but I will definetly take your word as you seem to know a lot more than me.
Old Dec 16, 2009 | 09:32 AM
HRTuning's Avatar
Parameters>Misc Options
Disable barometric pressure sensor - disables the internal barometric pressure sensor. Not all ECUs have this sensor.
Old Aug 10, 2013 | 07:57 PM
Rconnrad's Avatar
okay so i get the cel here and there so i finally checked it today and it came up with code 13.. I have a b20v running on crome using moates ostrich. i have it diabled on the tune but it obviously is still popping up what can i do..
Old Aug 13, 2013 | 09:51 AM
Spunkster's Avatar
Have you uploaded the calibration after disabling it?
TB123
Engine Management and Tuning
Sep 9, 2008 07:02 AM
TB123
Aug 21, 2008 04:42 PM
SpoolnByYou
15
Mar 26, 2006 08:43 AM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
.brad
Feb 26, 2002 03:30 AM
