GSR swap
Old Jan 19, 2010 | 01:05 PM
Shelbon222's Avatar
New User
Default GSR swap
I have a gsr with itr cams, dual valve springs, pnp very soon, stock gsr crank and ctr pistons which I got with the block. I'm about to out this motor in and I was wondering if the CTR pistons will work well the stock b18c1 block. It seems as though I may have to take the block to a machine shop just to get the pistons in (seems like their slightly too big for the cylinders), but before I do that I would like to know if there are any known issues putting CTR pistons in a gsr block. don't know if this helps but I also have a jvt aftermarket header and skunk2 intake manifold. Also I really like the idea of the ctr pistion because of their higher compression as I am going all motor.
Old Jan 19, 2010 | 02:38 PM
Top Ramen's Avatar
Default Re: GSR swap
This is the wrong forum for that question; try "all motor."
For now:
1) your compression will be just over 13:1
2) the high dome will limit your future cam choices
3) this has been covered in at least 50 threads. Search and you will find them.
As a new guy, the search button should be the first place you start.
enokcrx
23
Jul 9, 2013 07:04 AM
jdmhop26
Jun 12, 2011 03:40 PM
ALLMOTOR CRX
18
Jun 22, 2007 01:39 AM
CeeJayy
11
Dec 9, 2006 02:13 PM
seifer
Feb 10, 2006 06:47 AM
