ECU QUESTION
Old Feb 2, 2010 | 08:09 AM
cghorr01's Avatar
Default ECU QUESTION
I had a chip installed in my ecu. long story short the car wont run worth a **** with the chip in. The guy who put it in installed a socket so the chip can be installed/removed at will. If i remove the chip will the ecu revert back to stock or no? If no anyone on here wanna trade me a p72 for a socket p72 straight up?
Old Feb 2, 2010 | 08:28 AM
GhostAccord's Avatar
Default Re: ECU QUESTION
If the ECU was chipped/socketed properly. You should be able to open up the case and cut or remove the jumper at J1. That will revert the ECU back to stock.
On any ECU that I chip it is as easy as pulling the red jumper, pictured above, and your back to stock.
Old Feb 2, 2010 | 08:32 AM
cghorr01's Avatar
DUDE!! youre awesome. Thanks bro a lot seriously that worked perfectly and shes back to running good! I have some stock gsr parts and some assorted other misc parts so if u need something i will definitely hook you up for the hella good advice on my ecu problem
jthrasher1
Jan 25, 2010 08:41 PM
b4spaceage
Feb 3, 2006 03:57 PM
95excoupe
Feb 25, 2005 05:25 PM
Doubledeala
Oct 15, 2004 05:00 AM
ZUKI
Oct 10, 2002 10:40 PM
