Tuning help...
Old Jan 26, 2010 | 08:42 AM
SCV_GSR's Avatar
Default Tuning help...
Here the deal, I was tuning the car last night using Crome and Ostrich tuning in real time.
I was working on the idle and got it dialed in, at that time I decided to add boost tools and that when the problems started. I added the boost tools to the rom and the car died. I though ok, just restart right! Wrong the car will not idle at all and I am completely lost at this point. I went back to a known safe tune and still no idle. it will start run for 5-8 seconds go lean and stall. I thought i might have damaged the ECU, I tried a spare P28 and had the same problem.
Any help at this point would be great...
Old Jan 26, 2010 | 12:12 PM
Turbogixxer's Avatar
Default Re: Tuning help...
You did not damage anything, welcome to tuning crome. Reload the map and it should idle again.
Worst case, start over again with a new map.
Old Jan 26, 2010 | 12:46 PM
SCV_GSR's Avatar
Well this is what I tried so far, First thing I did was try and restart the car. that didn't work, the next thing I did was reload a new map still didn't start.
It is kinda of strange, I have 550cc injectors installed before the whole boost tools problem the car idled great now the only way to get it to idle is to input 325 for the injector size??? it will idle but run pig rich off idle.
I am going to reset the ECU i'm hopping that will help, any other suggestions?
Hiboost 2.0
Apr 30, 2013 06:38 AM
welfarepc
Sep 13, 2007 05:15 PM
champLSinteg
Nov 1, 2006 02:24 AM
PHILLIPDEEZ
Aug 26, 2005 11:27 AM
sCeRaXn
Nov 9, 2003 07:08 PM
