Is it possible to disable o2 sensor?How?
Old Jan 13, 2010 | 12:24 AM
baulum's Avatar
Default Is it possible to disable o2 sensor?How?
Hi,can we disable o2 sensor in a p06 ecu when chipped?
Old Jan 13, 2010 | 07:28 AM
HRTuning's Avatar
Default Re: Is it possible to disable o2 sensor?How?
Yes. You disable it right in whatever software you made the chip in.
Old Jan 13, 2010 | 07:51 AM
Relic1's Avatar
yes, but if you're doing it due to an O2 CEL you're likely going to have even larger problems.
This should be done for tuning only.
Old Jan 14, 2010 | 10:29 PM
baulum's Avatar
Thank you replying.Well my engine does not use o2 sensor.I want to chip my ecu and it can't be done as my ecu is a OBD2a,so i'm looking for a P06 chipped ecu in which we can disable o2,because most honda injection engines use o2 sensor.
Old Jan 14, 2010 | 11:14 PM
HRTuning's Avatar
I can get you a non-vtec ECU with o2 disabled, PM me.
adamdecimals
Apr 1, 2010 01:05 PM
variable
Engine Management and Tuning
Oct 16, 2009 01:59 PM
domino
Sep 29, 2005 07:47 AM
HONDA RR
Sep 16, 2005 03:53 PM
