CEL code 4 and Tacho not working
Old Feb 24, 2010 | 12:58 PM
stjohnsafc's Avatar
Default CEL code 4 and Tacho not working
Hiya guys, in need of some help if poss....
Just finished swapping a 94 B18c (JDM Integra SI) into my 96 EK D15y6 (UKDM)
I've used a 0BD1 to OBD2a Jumper harness and have wired in VTPS and Knock Sensor, re-using the original OBD2a loom with the Alternator and Distributor connector swaps..
Car started first time and is running, although its a bit rough, may have something to do with the fact i havnt yet connected the exhaust!
BUT.... I noticed that the Rev Gauge/Tacho isnt working at all, ALSO CEL code 4 (CKP sensor) is showing on the ECU
Can anybody shed any light on these problems? i understand they bot may have something to do with the Distributor?
Cheers
Lee
Old Feb 24, 2010 | 07:50 PM
mtber's Avatar
Default Re: CEL code 4 and Tacho not working
Cheers
Lee
Check your distributor wiring/distributor.
Use the factory helms manual to diagnose the code (google)
Old Feb 24, 2010 | 10:17 PM
stjohnsafc's Avatar
Thanks dude, unfortunately we dont get the Helms manual here in the UK, neither do we have anything for the Integra hah
Old Feb 24, 2010 | 10:39 PM
stjohnsafc's Avatar
I'm wondering as i had to re-wire the single connector OBD2a to fit the double connector OBD1 Dizzy wether i might have mixed up a wire?
Anybody have any wiring schematics for both OBD1 and OBD2a to see if i've done it correct!
Frany
Sep 2, 2015 07:40 AM
stjohnsafc
Feb 25, 2010 10:22 PM
stjohnsafc
Feb 24, 2010 10:15 PM
gdout90accord
Mar 30, 2005 12:59 PM
