Air temp sensor needed on OBDI?
Old Dec 25, 2009 | 09:58 AM
turbodcxbro's Avatar
Default Air temp sensor needed on OBDI?
My 98 hatch has a Type R swap in it with a chipped P28 and OBDII to OBDI conversion, I noticed when putting my AEM intake on that it doesn't have the air temp sensor anywhere? Do the OBDI ECU's need this input?
Old Dec 25, 2009 | 11:41 AM
HRTuning's Avatar
Default Re: Air temp sensor needed on OBDI?
Yes, unless you don't want it to be properly fueled when the temperature varies or heat soak occurs.
Old Dec 25, 2009 | 05:48 PM
mtber's Avatar
Simply change the IAT plug on your 98 ek harness to an obd1 style and wire it to the sensor in the intake manifold.
Old Dec 26, 2009 | 07:16 AM
I figured it needed one, I'm new to the Hondas but not new to the EFI engine management tuning. I didn't realize the IAT was located in the manifold, if thats the case I think its already hooked up. The swap was done when I bought the car so I'm not sure what was done though. Anyone got a pic of the location of the sensor so I know where to look?
EKiddd
Sep 9, 2013 10:43 AM
turbodcxbro
Dec 26, 2009 10:12 AM
marcj
Sep 24, 2008 08:38 AM
KevronsEG
Mar 13, 2003 04:09 PM
