installing injectors
Old Dec 14, 2009 | 11:00 PM
feriotypeR's Avatar
Default installing injectors
can i install my rc 310cc injectors w/o a tune?
Old Dec 15, 2009 | 12:06 PM
GhostAccord's Avatar
Default Re: installing injectors
Do you have a stock ECU?
Actually, No matter if your ECU is stock or not. It's not a very good idea to just add fuel without a tune.
Old Dec 15, 2009 | 12:27 PM
Matt55's Avatar
yeah if you do, your mpg will suffer, youl have too much fuel in the clylinders which cld lead to problems, but physically you can and nothing immediately is gna blow up
Old Dec 15, 2009 | 03:45 PM
feriotypeR's Avatar
what if i add a adj fuel regulator?
Old Dec 15, 2009 | 04:38 PM
Matt55's Avatar
you shld get a tune, is this for a stock motor?
Old Dec 15, 2009 | 05:15 PM
An Adj. FPR will not do anything if you have no way to monitor what it is that you are adjusting. You would still require a type of tune in order to adj. fuel pressure.
Old Dec 15, 2009 | 07:09 PM
93turbo16's Avatar
It definitely isn't a good idea to add bigger injectors and not scale them inside the ecu.
You can think of it like this. With 310cc injectors on a stock ecu you are running ~23% more fuel every where if you do not scale the injectors.
Now an O2 sensor can pull fuel out for normal driving, etc. But at WOT the O2 sensor has absolutely no effect on the final fuel value. So you will essentially have 23% more fuel than stock at WOT which is NOT a good idea.
Best bet is to just get the ecu chipped or if it is already chipped then to get it setup for the correct injector size. Then you should be good to go atleast to get the car to a tuner.
Old Dec 16, 2009 | 04:05 AM
feriotypeR's Avatar
i bought a hondata ecu thats tuned for 440cc injectors, can i use dat?
Old Dec 16, 2009 | 04:32 AM
q.man06's Avatar
If you have hondata, then go into the parameters and just switch it from 440 to your 310's. If you run that tune with the 310's, then you will run super lean everywhere causing excessive heat buildup-- this is with the assumption that it actually will run.
Don't half-*** fuel management, you will regret it.
Old Dec 16, 2009 | 05:37 AM
93turbo16's Avatar
True statement.
Old Dec 16, 2009 | 09:31 AM
feriotypeR's Avatar
ok guys, i was just makin sure, guess im gonna get it tuned, thanks guys
diatibe24
Mar 20, 2015 11:48 AM
1SickHb
Dec 9, 2005 08:13 AM
SIISFLY
21
May 27, 2005 07:25 PM
EE_Chris
May 22, 2002 04:56 AM
BUSAFREAK
Jun 25, 2001 09:50 AM
