crome basemap
i am having major problems with my tune. looking for new basemap
75mm vitaras
eagle rods
dsm450cc
gm 3bar map
cast manifold
57 trim turbo
zex 59300 cam
skunk 2 intake manifold
b16 tb
255 fuel pump
oem fpr
i opened crome p30 bin, imported p28 maps, removed checksum and added quick datalogger and rtp, added boost tables 3 bar map 6 boost tables, dsm 450cc(90-94 blue tops if correct)(offset 0.00 see 3nd image below)
this is where i left off.
low cam ing
low cam fuel
advanced tab when setting fuel multiplyer
Injector offset
not sure where to go from here. i have hulog and ostrich and chip burner.
hulog - com 8
ostrich - com 9
burner - com 6
do i need to change com ports to match lower numbers
75mm vitaras
eagle rods
dsm450cc
gm 3bar map
cast manifold
57 trim turbo
zex 59300 cam
b16 tb
255 fuel pump
oem fpr
low cam ing
low cam fuel
Injector offset
hulog - com 8
ostrich - com 9
burner - com 6
can any one help me get my car to idle. i have played around with the offset when setting the injectors. 47 offset for 450 injectors when tried to start motor i will crank over and wideband will read 14.x but wont run
sorry if it's a dumb question but did u change in your multiplier calculator your injector size? from what i see in crome you have your low cam fuel tables the same as a stock p28 with 240cc injectors, which with 450's would be to much. you could be drowning your cylinders
What DSM injectors do you have? Blue top (90-94) Black top (95-99) that will determine the correct battery offset.
likwidchz
Engine Management and Tuning
Sep 12, 2011 06:57 PM
Golden Eagle
Sep 13, 2010 07:19 AM
tekturbo
Jun 6, 2008 03:06 AM
