sohc high comp. tuning
Old Jan 20, 2010 | 07:14 PM
efjones9's Avatar
Default sohc high comp. tuning
Just wondering what the best map would be for a single cam non vtec compression would be between 10.5-11.0 also will probaly have a level 2 bisimoto cam and cam gear.
Old Jan 20, 2010 | 08:21 PM
HRTuning's Avatar
Default Re: sohc high comp. tuning
Getting it tuned properly with a wideband...
Old Jan 20, 2010 | 08:46 PM
mtber's Avatar
There wouldn't be a "best map". Get the car dyno tuned using an obd1 tuning system such as hondata.
Old Jan 20, 2010 | 08:58 PM
efjones9's Avatar
So I can't tune wen I'm obd 0 right
Old Jan 20, 2010 | 10:56 PM
HRTuning's Avatar
Wrong
www.pgmfi.org
Old Jan 20, 2010 | 11:00 PM
mtber's Avatar
You can, however most tuners don't support obd0 ecus anymore.
Old Jan 21, 2010 | 06:53 AM
HRTuning's Avatar
Yup, you'll more than likely be tuning yourself if you stay OBD0.
Old Jan 21, 2010 | 09:39 AM
efjones9's Avatar
Wouldn't mind that. I hear its expensive. Wat would I need to tune myself.? Is there a way to tune without burning a new chip every time? Like a re-writeable chip or something lol
Old Jan 21, 2010 | 09:41 AM
HRTuning's Avatar
A Moates Ostrich Real-Time Emulator can be used for real-time tuning with supporting software.
Old Jan 21, 2010 | 09:52 AM
efjones9's Avatar
Koo ima check that out. I wana get my engine performance ase cert. Soon so I'm studying this area so this might be helpful.thanx
Old Jan 21, 2010 | 10:18 AM
HRTuning's Avatar
np
Old Jan 28, 2010 | 08:18 PM
NASOHC's Avatar
Anyone know how a stock OBD2 ECU would run on a SOHC motor that was bumped from 9.3:1 to 10.65:1? Just looking to run it for a few weeks till I can get car tuned with my AEM. I won't try it if not recomended. Just want some opinions and suggestions.
Old Jan 28, 2010 | 09:41 PM
sanimalp's Avatar
$cat /dev/urandom
my thought is if you are worried enough to ask, then you should get it tuned before driving it.
Old Jan 29, 2010 | 11:27 AM
Top Ramen's Avatar
Can't you jump down an OBD1 ECU? Then you would have a bunch of good tuning options (like Neptune, etc.)
http://www.xenocron.com/ecu-conversi...f8c2b49f3399a5
Old Jan 31, 2010 | 12:06 PM
Thomascivicsi's Avatar
X2.....
flatblack-h22
Engine Management and Tuning
Mar 18, 2009 11:55 AM
danno33
16
Nov 3, 2006 12:39 PM
MNEJ2GUY
Aug 19, 2004 08:23 AM
speeddave
May 23, 2003 09:29 AM
pissedoffsol
Mar 13, 2003 09:47 PM
