p28 or p72
Old Jan 1, 2010 | 01:15 PM
93bubble87's Avatar
Default p28 or p72
sup guys i got a 97 gsr in a 93 eg. i currently have a stock p72 obd1 hooked up.. one of my buddies got a factory p28. if i swap will i have any positive effect on the caR?
Old Jan 1, 2010 | 01:24 PM
HRTuning's Avatar
Default Re: p28 or p72
No. The P28 is not setup stock with the proper maps for a GSR. I'm not sure why you'd want to trade anyway. The P72 is worth more. If you're trying to get a tunable ECU you can have yours chipped. If the P28 is chipped and you want to trade your stock P72 for it in order to have a tunable ECU, it's almost a decent deal. Just make sure it's already programmed to run your GSR engine.
Old Jan 1, 2010 | 01:29 PM
93bubble87's Avatar
hmm ok.. ive heard different i figured i'd ask
Old Jan 1, 2010 | 01:40 PM
HRTuning's Avatar
The P28 is tuned for a D16z6, the maps don't deliver the fuel and timing a GSR needs. On top of that the P28 can't control the Intake Air Butterflies so you lose out there as well.
Old Jan 1, 2010 | 01:41 PM
93bubble87's Avatar
so basically the best ecu mod to make is to chip my p72* after i add some mods right
Old Jan 1, 2010 | 01:44 PM
93bubble87's Avatar
but heres the thing.. i bought the p72 off of craigslist from some kid with an accord. i think it may be chipped. i opened it up nothing after market at all ... i tried to locate any different resistors and didn't seem to find anything. my ecu vtec pops at different rpms at different gears. ex 1-2-3-4-5 is 5k-5k-45k-45-45k. and some times i get confused bc they pop differently ... also the car is running rich ...having a white car and a black rear sucks
Old Jan 1, 2010 | 02:00 PM
93bubble87's Avatar
hr tuning.. i checked these guys out from your links they are pretty close to me. are the any good? http://www.xenocron.com/index.php
Old Jan 1, 2010 | 03:08 PM
HRTuning's Avatar
Yes, chipping your ECU when you're ready for tuning is the best route to go. It may be chipped already, you can easily find out by popping the cover off... but VTEC will come in at different RPMs depending on the load you're at.
Chris (Xenocron) is great to deal with. He'll take care of anything you need.
Old Jan 5, 2010 | 05:56 AM
crxb16a90's Avatar
stock p72 engage at 45. i found stock guage rpm not 100 percent, my 2000 si cluster vtec kick in at 5200-5400, but when i'm tuning with crome, it show, 5000 everytime. so i would pay too much attention, but if u are having vtec sometime then don't, need to double check your wiring and also any cel. but come down to it, there something p28 don't have compare p72, is the knock sensor board, u can get a kit to have one for p28.
Old Jan 5, 2010 | 05:28 PM
93bubble87's Avatar
im getting the p28 chipped tomorrow by outlawzz in clifton nj... would the knock sensor delete help me or hurt me ?
Old Jan 5, 2010 | 05:38 PM
ruskie02's Avatar
well on my 99 ek with a jdm h22 i went with a p28 n went with the hondata s100 n tuned it it came out really good for me, my stock p17 ecu was horrible it kept kicking on check engine lights
Old Jan 5, 2010 | 07:59 PM
crxb16a90's Avatar
Well here's the problem is the p28 chip for what? What kind map? Second I wouldn't let go a p72 ecu over a p28, u cab get chipped kit cheap and get a base map burn for u. I would love to run p72 instead p28. The knock board is up to u. Is something u have to decide if u gonna run knock or not, with Crome u can disable knock in p72 ecu. But sound like u already made up ur mind. Go with either
HEADS OR TAILS
Dec 30, 2009 08:27 PM
civicb16eg
Aug 20, 2007 06:59 AM
GDM93Si
12
May 9, 2006 01:58 PM
Zion-I
Feb 12, 2006 09:32 PM
vizsual00
18
Oct 23, 2003 02:33 PM
