check engine light on but no code,hondata
Old Dec 16, 2009 | 07:04 PM
ericrx_88's Avatar
Default check engine light on but no code,hondata
I got a base map for my setup running e85 put it in and I get a check engine light. But there is no code. The car runs but bogs when you give it a little gas. If you let the car warm up its ok. I have not driven the car just started it up. I know I need a tune but just wanted to make sure everything is ok before taking it to the dyno. You guys think its just the tune on it or could it be the ecu. Thanks
Old Dec 17, 2009 | 08:40 AM
Spunkster's Avatar
Default Re: check engine light on but no code,hondata
What Hondata system and how are you checking the code?
Old Dec 17, 2009 | 11:59 AM
ericrx_88's Avatar
Its a s100 in a 00 si. Motor is build 2.0 gsr block 13.1 comp. I'm jumping the harness. Lights in but when I jump it light just goes off. I've read bout cutting the j1 conection so ill try that. Hoping its just the tune
Old Dec 17, 2009 | 03:10 PM
Spunkster's Avatar
If it was tuned with Romeditor 4 the service check connector will not work unless the chip was burned using the new beta version of software.
Old Dec 17, 2009 | 03:17 PM
ericrx_88's Avatar
Thanks ill call and ask the place I got the base map from
Old Dec 17, 2009 | 05:24 PM
mtber's Avatar
In other words, you need to visit a dealer that has an s200 system and romeditor v4 to troubleshoot the situation.
ericrx_88
Dec 14, 2009 09:03 PM
97_hatch
May 19, 2008 10:07 PM
0-400DC2-R
Sep 28, 2003 11:48 AM
ahobbs
Sep 12, 2003 08:41 AM
jjaeschke2
Apr 20, 2003 05:14 AM
