OBD1 CEL Code 2
Old Dec 30, 2009 | 04:12 PM
Circaskaterr's Avatar
Default OBD1 CEL Code 2
I looked it up and online it said Oxygen Content B so i just wanted to know if that would be the O2 Sensor or if its something else
Old Dec 30, 2009 | 05:58 PM
GhostAccord's Avatar
Default Re: OBD1 CEL Code 2
Code 2 is for O2 sensor #2(B). From what I have seen the 93 GS didn't come with 2 O2 sensors. Do you have two O2 sensors on your car? If you do then O2-B would be the second one (furthest) from the engine.
Are you sure your not seeing two long flashes = code 20 ELD?
Old Jan 1, 2010 | 01:54 PM
no its 2 shorts ones it might be becuase the ecu is out of a different car but would that cause my idle to be messed up cause before my ecu fried my idle was fine but then i got this one for a short fix and my idle is higher and bounces i tried to clean the screen in the iacv already
Old Jan 1, 2010 | 04:29 PM
What ECU is it that you are running now?
B_Swapped93
Jan 29, 2013 04:18 AM
HommeDeBois
15
Jul 16, 2011 02:56 PM
MindLess311
Jul 2, 2006 05:36 PM
crx1racing
May 31, 2005 06:11 PM
