Convert Crome P72-base to P30-base
Old Apr 16, 2011 | 07:23 AM
josephcmiller2's Avatar
Default Convert Crome P72-base to P30-base
I have a stock LS with stage 2 cams (Crower 403) and I've been tuning it with Crome. I used P72 as my base and I'm pretty much done for now. I've seen most people recommend to use a P30 base.
What are the advantages to using a P30 base? Should I use that instead? What's the easiest way to copy the maps from one to the other? I've noticed that some of the advanced tables are completely different.
Old Apr 16, 2011 | 10:27 AM
mouab18c1's Avatar
Default Re: Convert Crome P72-base to P30-base
Google it. There's a guide on how to do this.
Old Apr 16, 2011 | 04:48 PM
MrDomino's Avatar
http://www.xenocron.com/install/CromeGuide.htm
edit: I'm not sure if this will answer your question but it might.
Old Apr 16, 2011 | 06:28 PM
mtber's Avatar
Your not going to really see a night and day difference by switching to a p30 code base.
You are still injecting the same amount of fuel & timing etc...
Old Apr 17, 2011 | 05:02 PM
met-tuning's Avatar
no need to as the base codes can run all the same features
Luke G.
Engine Management and Tuning
Nov 26, 2011 06:28 AM
Integra4lyfe069
Sep 18, 2011 07:46 AM
maniach4x
Jul 17, 2007 11:18 PM
integraboy22
Feb 10, 2007 01:18 PM
PINKS
50
Jan 7, 2006 07:39 AM
