Crome pro ecu code 24
Old May 15, 2011 | 09:03 PM
EMTIV09's Avatar
Default Crome pro ecu code 24
It's a b16a crx with a chipped obd1 ecu. I have tried different ecus checked the codes via jumping the service connector and via data logging and it still has the cel lit up and showing code 24 and I have hunted for weeks and no info on the ecu code.
Old May 15, 2011 | 11:18 PM
mouab18c1's Avatar
Default Re: Crome pro ecu code 24
Are you positive it's 24? I have never heard of or seen a code 24.
ECU CODES (Thanks to Drag III Integra)
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
67 Catalyst low efficiency. (same as P0420)
70 Automatic Transmission Malfunction w/AT Controls
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
Old May 16, 2011 | 06:03 AM
HAMOTORSPORTS's Avatar
That code 24 is just a bogus code. (Thanks to Crome and their wonderful software :/ ). If you can copy your maps over to another base )ie: transfer your b16 maps from the p30 base code over to P72 base, it should get rid of it..
93b20z
May 18, 2009 04:59 PM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
lYellowDragonl
Nov 6, 2005 05:20 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
