Afr on wideband
Old Mar 2, 2011 | 03:13 PM
350znal's Avatar
Default Afr on wideband
well, the honda is out till i get some more fuel and a tune. Got the header on, 3in exhaust and the aem wideband..
idle afr: 12.5
wot afr below 6200: --
wot afr after 6200: 16.8
So it's getting no bottle for now.
Think the injectors or pump is going out? Bad o2( even though cel isn't on for it) or just need a tune with just i/h/e?
Old Mar 2, 2011 | 06:25 PM
mouab18c1's Avatar
Default Re: Afr on wideband
You need a tune!
AFR for idle should be around 14.7
WOT should be no higher then 14
Old Mar 2, 2011 | 08:58 PM
350znal's Avatar
I know what the afrs should be. This is on a stock p13 also
Old Mar 3, 2011 | 03:24 PM
SDLEDS's Avatar
You probably just need a tune. It wouldn't be a bad idea to check your fuel filter though and send out to have your fuel injectors cleaned.
Old Mar 3, 2011 | 04:24 PM
350znal's Avatar
going to replace the filter, fp and put on a afpr.
Thinking the person who did the swap may have left the cx fuel pump in the car also.
Old Mar 4, 2011 | 01:50 PM
92egls's Avatar
as i stated on ars unless the pump is dieing the cx will support the h with your mods the car being a cx is irrelavant the same fuel pump is used from the cx to the si
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/fuel-pump-same-egs-eks-2604677/
Old Mar 4, 2011 | 03:10 PM
350znal's Avatar
Going to order this on tues.
http://www.xenocron.com/diyer-intro-...age-p-238.html
minus the wideband, since i already have one. going to be using crome pro and adding the tuner harness
Old Mar 4, 2011 | 07:31 PM
bigD's Avatar
or you could go with a much better option for almost the same price http://www.xenocron.com/neptunertp-d...new-p-223.html
Old Mar 4, 2011 | 07:42 PM
mouab18c1's Avatar
Lose the Ostrich and get Neptune RTP
Old Mar 8, 2011 | 01:05 PM
350znal's Avatar
Well, for night i a friend had a v-afc for cheap( i mean really cheap) to use to get the afr straightened out till i can get the money for the neptune rtr.
On a side note the afr is now 13.1 in 3rd from 4k to 7800 at wot. Car runs 10 times better than what it did before.
The vafc hack is only temp, i know it's just a bandaid fix.
JUGGIEGAILS28
Feb 19, 2004 12:09 PM
Prevail
Dec 13, 2002 07:16 AM
bigblockEG
Apr 5, 2002 08:56 AM
