01 Accord Engine run bad
Old Feb 27, 2011 | 05:52 AM
DalAccord1's Avatar
Icon6 01 Accord Engine run bad
2001 Accord VP 2.3L Powertrain basically all stock. Intermittently has hard time starting. Sometime starts quick, sometimes not. Goes to smooth idle but as soon as I press the throttle it chokes, sputters or dies. If I can get the car moving above about 2500rpm it smooths out again.
Replaced the dual sensors under the pulleys for the Crank and knock sensors. Rechecked timing and balance belt alignment. New plugs, wires cap, and rotor. Have also checked and reset all valves.
intermittent codes: 1399, 300, 301, 302, 303, 304
I know these are all ignition codes, but had same codes a year ago when had injector problems.
Old Mar 7, 2011 | 08:05 AM
Cap'N Chronic's Avatar
Default Re: 01 Accord Engine run bad
I have a similar problem with my B18B1 swapped 98 civic. It starts fine but when I try to go it chokes out and lurches forward until I start moving.
Old Mar 7, 2011 | 09:42 AM
Accordin2me's Avatar
Shouldnt this be in another thread?
johhnytsunammi
Jul 2, 2017 01:20 AM
DalAccord1
Feb 21, 2011 12:57 PM
Korben
Feb 18, 2011 05:06 PM
Formula Racing
Apr 4, 2006 06:04 PM
