Question: Setting up datalogging on s300
Old May 1, 2011 | 10:15 AM
SL0WEGG's Avatar
Default Question: Setting up datalogging on s300
This may be a silly question to some. I have an idea of how I'm going to set this up, Just unsure if its going to work like I think it will lol. Within the S Manager you can pick and choose the output/input(I can't think of this exactly right now but you get the picture) and whenever you set whichever one you want IE: Jumper plug for CEL. Am I able to just wire in from one to the other through a switch to set this up no problem? What if I choose the a/c, would you send a power to that pin or a ground? Any help would be greatly appreciated. Thanks in advance.
Old May 1, 2011 | 12:43 PM
mtber's Avatar
Default Re: Question: Setting up datalogging on s300
You can setup on-board datalogging based on condition only i.e. over x mph and x tps or you can set it up via a switched input.
Read the smanager help file, it is there for a reason :-)
http://hondata.com/help/smanager/index.html
Old May 2, 2011 | 06:16 PM
SL0WEGG's Avatar
I'd like to set it up on a switch. I've read the help file. Since i'm not using a/c anymore and the pin is b5 as shown in the help file there. Do I set I send a positive signal to the b5 pin or a neg signal? I know it sounds dumb as hell lol But i'd hate to fry my ecu sending a + when it should be -.
Old May 3, 2011 | 05:04 AM
mtber's Avatar
You can inverse the input in the smanager. I would send it a ground signal.
Old May 6, 2011 | 04:36 PM
SL0WEGG's Avatar
Thanks
RadekSkylark
Engine Management and Tuning
Apr 7, 2010 11:19 PM
slambedcivic
20
Jun 18, 2008 04:00 AM
mikeycivic
19
Feb 19, 2008 12:23 PM
S@nt0s
Feb 10, 2004 11:22 PM
