L2H2 and S300
Old May 14, 2011 | 10:10 AM
lsturbo33's Avatar
Default L2H2 and S300
I need help from someone that has wired this up before. I've searched and can't find exactly what I'm looking for. I have a NTK wideband sensor that I need to wire up with S300. I don't want to wire it to any of the factory o2 wiring and I already have an extra bung in my downpipe for the wideband. The sensor wire colors are as following. I need someone to tell me where each one needs to go. I have located wire d10 on the harness but have not yet removed r136 or r138.
YELLOW
BLUE
BLACK
GREY
WHITE
Old May 15, 2011 | 04:33 AM
mtber's Avatar
Default Re: L2H2 and S300
You can't wire an NTK sensor directly to the ecu.
The NTK sensor must be run off a wideband controller which will send a 0-5 volt signal to an input on the ecu (ELD).
The factory obd1 ecu cannot act as a wideband controller...
Old May 15, 2011 | 10:05 AM
lsturbo33's Avatar
Thanks. That's I'll pick up a controller.
Old May 16, 2011 | 05:20 PM
mtber's Avatar
Awesome, good luck
accordianex
Feb 19, 2006 07:07 AM
Batoutahell
Jan 29, 2006 06:45 AM
nd8ch
Jan 1, 2003 12:40 AM
slwazgsr
Sep 30, 2002 02:48 PM
Flamenco-T
Jul 7, 2001 04:38 PM
