s300 issues
Old May 8, 2011 | 02:28 PM
hybridpatient95's Avatar
Default s300 issues
i installed my aem wideband to my s300 and now for some reason the tps display is red and stays are 0 not letting me go over 2000rpm
if i hold the gas at 2500, rpms will drop and rev up again
also i cant seem to get my s300 to read the same as my wideband does.
the white output from aem goes to the eld wire on the ecu.
eld is selected on s300
any ideas?
Old May 8, 2011 | 06:48 PM
mtber's Avatar
Default Re: s300 issues
The s300 is not the issue.
Make sure you actually wired the input to the CORRECT pin on the harness.
Make sure you removed the correct resistors you claim you did r136 and r138 & not r137 in the middle which is a tan colored resistor.
Old May 8, 2011 | 07:01 PM
yes r136 and r138 were snipped the middle one was left alone.
but for some reason i cant get it to be as accurate as the gauge. its barely moves in value while the wideband is totally different..
also the tps problem only started after i snipped the 2 and i have soddered them back and nothings changed
Old May 8, 2011 | 07:04 PM
oh yea with the Key on engine off the tps stays in the green. once the car is started it goes red
Old May 8, 2011 | 07:12 PM
mtber's Avatar
Sounds to me like you tapped into the wrong wire(s)
You need to do the following:
1. Review http://www.phearable.net/tech/wiring...schematics.gif
Make sure you actually cut the ELD wire & ran the 0-5 volt white wire from the wideband output to the ELD pin at D10
2. With the key on but engine off, measure the voltage at pin D11
You should see .45 or .50 volts.
3. With the key on but engine off, have some one hold the throttle down on the car.
Measure the voltage at pin D11. You should see around 4.5 volts
Old May 9, 2011 | 02:52 AM
okk thanks ill give this a try later on today
kissifur
Jun 19, 2014 04:22 PM
ZCHondaCRX91
Jul 7, 2011 02:19 PM
accordguy96
May 31, 2004 01:32 PM
E Swift
Apr 3, 2004 06:09 AM
