S300 launch control setup with e85
Old Apr 22, 2011 | 07:52 PM
project-boosteD's Avatar
Default S300 launch control setup with e85
I'm trying to set up my launch control but don't know a good starting point with fuel and timing with e85. My set up: b18c 84mm type r head, Bosch 1600 inj, msd 6al, 3inch inline pro exhaust all the way back , put 491 at 17psi
Any input will be greatly appreciated
Old Apr 23, 2011 | 05:20 PM
Default Re: S300 launch control setup with e85
Bump
Old Apr 23, 2011 | 06:51 PM
mtber's Avatar
Launch control point is going to be different on every vehicle.
You need to go to the track & figure out what your car/track/tire combo likes.
Start at lets at 5500 rpms and go from there etc...
Old Apr 24, 2011 | 05:10 AM
Thanks for your input, I'm more worried about the wrong timing and fuel addition that I might mess up something
Old Apr 24, 2011 | 05:20 AM
mtber's Avatar
Read this thread: https://honda-tech.com/forums/engine-management-tuning-124/dialing-anti-lag-2-step-2926286/
You likely won't need to use ant-lag to get a good 60 ft time & launch.
Every application is different.
Old Apr 24, 2011 | 07:18 AM
portenio78's Avatar
For starters put the Fuel enrichment at 200 and the ignition timing at -20. For example, if you were to change the ignition timing to -28, it will build boost faster. Just play with it, and see what you like.
Old Apr 24, 2011 | 08:11 AM
mtber's Avatar
What tire/axle/tranny/engine/turbo setup do you have?
Old Apr 24, 2011 | 10:25 AM
Dss 5.9... 24 10 13 Mh's... Gsr trans carbon syncros heat treated gears, stock itr diff... Full race top mount gt4088r full race 3" DP...
Old Apr 24, 2011 | 11:14 AM
mtber's Avatar
Set your revlimit to a fuel + ignition cut style.
Start your tire pressure at 8-10 psi for your first run.
Simply use a standard two step & start at around 6000 rpms for a launching point.
You should be good to go. If you experience some bogging off the line, raise the two step as needed.
Leave the ignition retard & enrichment values at 0.
Old Apr 24, 2011 | 12:07 PM
portenio78's Avatar
Is it bad to have the rev limiter set to just cut fuel?
Old Apr 24, 2011 | 03:52 PM
mtber's Avatar
No, however you will build more boost with a fuel + ignition cut on s300 then just a fuel cut.
Old Apr 24, 2011 | 05:26 PM
Thanks for your help guys!
Old Apr 24, 2011 | 06:04 PM
mtber's Avatar
No problem, have fun!
Old Apr 27, 2011 | 07:17 AM
sicones's Avatar
How would cutting fuel+ignition build more boost then just cutting fuel?
Old Apr 27, 2011 | 09:49 AM
mtber's Avatar
I don't feel like typing a long description of why it does.
It just does, just like cutting ignition only builds more boost then just cutting fuel....
Old Apr 28, 2011 | 03:11 PM
sicones's Avatar
I ask because I have tried both and have not noticed any appreciable difference.
Old Apr 28, 2011 | 03:33 PM
96 GSR-T's Avatar
I certainly noticed a difference with fuel+ignition cut vs just fuel
EL TYPE R
Mar 7, 2013 09:33 AM
v8killaz
Sep 9, 2012 03:00 PM
1junkycivic
Nov 5, 2008 09:49 AM
Pippen_001
Jul 26, 2007 01:24 PM
