NepTune shift indicator
Old Apr 27, 2011 | 04:42 PM
JDMEMone's Avatar
Default NepTune shift indicator
So I have a B16 that i just had tuned and I have a weird question... is NepTune's shift indicator where the RPM's dip and bounce back?
Old Apr 27, 2011 | 04:44 PM
LovemyEKhatch's Avatar
Default Re: NepTune shift indicator
The shift indicator would be where the checkengine light comes on at what ever rev limit you have it set for.
i believe your talking about launch control.
Old Apr 27, 2011 | 06:26 PM
mtber's Avatar
Your rpm's shouldn't dip and bounce back during acceleration.
Neptune has a shiftlight feature that lights up your check engine light as a shiftlight.
Old May 1, 2011 | 05:06 PM
JDMEMone's Avatar
here is a short clip it does it at 9k everytime....
Ive tried 3 different dizzys, 1 cluster and 5 grounds on the engine.
comments welcome
Old May 1, 2011 | 05:07 PM
JDMEMone's Avatar
http://www.youtube.com/watch?v=AZFn9MjVtu8
Old May 1, 2011 | 06:45 PM
HRTuning's Avatar
That is not the shift indicator, as the check engine shiftlight is the only indicator we offer for that. If you have ignition cut and you're hitting the rev limit that could cause the tach needle to drop. If you're not hitting the rev limiter then it's something physical with your wiring, components, or cluster, as NepTune can't control your tach.
Old May 2, 2011 | 07:03 AM
socallmechris's Avatar
it looks like your rev limit is set to be an ignition cut and not a fuel cut.
if you use the ignition cut, the signal from the dizzy to the tack in interrupted and will make the needle go crazy.
try changing i to a fuel cut only and see if that fixes it
Old May 2, 2011 | 07:28 AM
this might help a little bit
b20vteg757
Engine Management and Tuning
10
Nov 18, 2013 09:43 AM
BB6racer
Aug 9, 2006 09:21 AM
01_prelude
Oct 5, 2005 08:23 AM
veeDUB
Apr 2, 2002 05:51 PM
