S300 setup questions
Old Mar 14, 2011 | 06:38 AM
iskate2's Avatar
Default S300 setup questions
Im just learning S300 (noob alert!!!) and I cant see throttle on this graph over 40%.
When I look under my "sensors" or "Display" i can get resolution from 0% to 101% (im on ITB's, still gotta work out that last 1%) without any problem.
Everything seems to be functioning properly, but I cant read anything on this damn graph over 40% throttle!!!
Can someone help me set this up right?
Thanks,
Matt
Old Mar 14, 2011 | 06:50 AM
mtber's Avatar
Default Re: S300 setup questions
Click options, then click boost tables. This will show the expanded columns up to 100% throttle on the alpha-n map. Do your self a favor, click help, contents, search tab, type in alpha-n and read.
Old Mar 14, 2011 | 07:40 AM
iskate2's Avatar
Perfect. Thanks, I read it, it was pretty informative.
Now for the RPM, How do I raise the scale a bit?
Old Mar 14, 2011 | 08:29 AM
mtber's Avatar
You shouldn't have to unless you plan on trying to make power above 8900 rpms in the high cam tables...
Old Mar 14, 2011 | 06:26 PM
iskate2's Avatar
Yes I know, but I like to have a margin to work in for visual reference. Plus it helps to learn how to navigate the software for future use. I wouldn't have guessed (nor did I) that the full throttle range of my N/A setup would only be visible under the boost tables, but there it was.
Thanks for your help mtber. Ill be in touch with you about dyno tuning in late April after this semester.
Old Mar 15, 2011 | 10:46 AM
mtber's Avatar
Awesome!
boostincoupe
Sep 3, 2005 01:54 PM
piggypen
Feb 15, 2005 10:09 PM
99lspwr
Feb 4, 2004 04:45 AM
Goldfingiz
Jul 22, 2003 01:26 PM
