Virgin p06?
Old Feb 25, 2011 | 12:36 PM
mouab18c1's Avatar
Default Virgin p06?
I just bought this obd1 ecu from a guy I do business with once in awhile. He pulled it out of a wrecked 94 four dour civic coupe. Barcode is 37820-P06-A52. The thing is that it already has some weird looking 28 pin chip in it already with j1 already jumped as well as a few other resistors.
I was just planning on taking it out since I will be converting/chipping it anyways. Just never seen one like this before.
Old Feb 25, 2011 | 02:36 PM
HRTuning's Avatar
Default Re: Virgin p06?
That's a chip from the factory.
Old Feb 25, 2011 | 06:26 PM
mouab18c1's Avatar
Can I just take it out?
Old Feb 25, 2011 | 10:34 PM
HAMOTORSPORTS's Avatar
Yes, but be very careful. Whenever I come across these I cringe because it is so easy to damage the tracks on the board when trying to remove the factory chip. The only nice part is that you already have the 74HC373 in place along with the other components so all you have to do is replace the 28 pin chip
Old Feb 25, 2011 | 11:05 PM
mouab18c1's Avatar
Thanks for the reply HA, I did some research on it and verified I could take it out and replace it. I've already converted everything over. Just have to go buy more desoldering braid at Radioshack and tackle it down tomorrow.
HRTuning's Avatar
Honestly the easiest way to remove these is to cut out the chip itself and remove each leg by itself. It's actually very quick and leaves everything intact.
Old Feb 25, 2011 | 11:07 PM
mouab18c1's Avatar
That is how I was planning on doing. Snip the chip out and just heat up one side of the board and pull out the pin from the other side. Thanks JR
Old Feb 28, 2011 | 05:50 PM
mouab18c1's Avatar
Update: Got everything done and it works great.
Travis R
12
Jun 21, 2011 02:48 PM
Nick97hatch
Engine Management and Tuning
Mar 13, 2011 08:00 AM
en00be
Feb 9, 2009 10:43 AM
berb_15
Oct 1, 2008 02:23 PM
UNforgivABLE
Mar 12, 2006 04:35 PM
