all motor tuning vs forced induction tuning
Is there a difference in tuning an all motor car and a turboed car or is tuning tuning no matter what your set up is ? If so what are the differences.
Re: all motor tuning vs forced induction tuning
Yes there is a difference, in fact there is a difference in lets say a high compression, large cam all motor to a stock cam, stock compression tune etc...
The differences are ignition timing, target air fuel ratios (lamda), vtec point etc...
So which one is easier ? what i was wondering is if you can tune an FI motor would you be able to tune the all motor or vise versa or are they just to different.
For example on a B18c:
Do you guys use different ECT and IAT ignition compensation for boost and N/A?
How much timing you normally pull for high ECT and IAT temps generally?
Get everything else tuned and then sit in a parking lot and adjust ECT comps as the engine gradually warms up. Add/Subtract fuel to maintain a steady 14.70 at idle.
edit: 777 posts. Guess I'm done contributing to all forums except GDD for all of eternity.
