Injector questions
Old Feb 24, 2011 | 03:32 PM
flickster29's Avatar
Default Injector questions
I put a b18b in my 98 coupe and I was wandering if the injectors from my d16y7 work on my b18b or are they to small.... And I got a single cam computer in it now just to run it and it is missing at low rpm and don't got much power. If I com vert it from obd2a to obd1 computer will that help out my missing and hesitation.
Old Feb 25, 2011 | 10:34 AM
Default Re: Injector questions
anyone
Old Feb 25, 2011 | 12:31 PM
mouab18c1's Avatar
You need your b series injectors. And you need to run a ls basemap on a chipped ecu or run a ls ecu.
Old Feb 25, 2011 | 05:03 PM
So that could be why it's running bad then right...
Old Feb 25, 2011 | 10:36 PM
HAMOTORSPORTS's Avatar
You can use the Y7 injectors (they are the same cc as any B series injector). If it is misfiring, then you have something hooked up wrong.
Old Feb 26, 2011 | 07:43 AM
mtber's Avatar
d16y7 injectors = 240cc high impedance
b18b injectors = 240cc high impedance
You need to be running the correct engine computer for the engine you are running.
You also need to resolve any check engine lights (malfunction indications codes).
Project_EK
Jul 24, 2006 06:42 AM
Capt. Jimbo McSubipants
Apr 16, 2005 11:06 AM
theslugbug
Mar 10, 2004 09:21 PM
TurBoTeG
Jul 12, 2002 05:55 PM
SpoolinEK
May 12, 2002 10:58 AM
