2000 civic help 4k rev issue
Old Feb 23, 2011 | 11:13 AM
kustom_2323's Avatar
Icon2 2000 civic help 4k rev issue
Car: 2000 civic
Engine harness: SI
motor: 1996 b18b1
Ecu: OBD2B si also have a obd2a ecu with jumper harness
well i had my motor wit obd2a ecu in my 97 civic with a single cam v tec harness. i crashed that ... so i bought the above listed car and pulled the swap out the old car. now that i have the car running it wont rev past 4k. i tried both ecus and still nothing. im running out of options. although the car does drive, hit me with your thoughts lol and suggestions? i need this car running top of the line. and 4k rev limiter is NOT helping thanks
Old Feb 23, 2011 | 02:02 PM
mouab18c1's Avatar
Default Re: 2000 civic help 4k rev issue
Did you switch your tps and map sensor plugs around?
Old Feb 23, 2011 | 07:23 PM
2k.civic.si's Avatar
what ecu is in the car? how you even bothered to pull the codes since it obvious the ecu is in limp mode?
Old Feb 24, 2011 | 04:54 AM
going to try that later today, i just got info on which sensor is which. the map sensor didnt reach to the tps soo i figured they were right, but im going to double check
Old Feb 24, 2011 | 04:57 AM
right now i have a obd2b b16 ecu.. then i have a obd2a ls ecu with a jumper harness. both stop at 4k. as for the codes i have not pulled them based on the CEL is not on but then again someone said the bulb might be out so i have that to check soon to. i will be stopping by autozone to see if any codes come up thanks.
Old Feb 24, 2011 | 09:56 AM
mouab18c1's Avatar
Just turn the key to the ON position. CEL should light up for a bit if it is not out.
Old Feb 25, 2011 | 07:41 AM
very true that def dont come on then lol... must have burnt out in the crash and here i thought the swap was check engine free lol... dam well off to autozone i go hopefully if i have time between shifts. ill kepp u guys updated! thanks
boostedblue23
Apr 6, 2018 06:53 AM
randol_8o8
Engine Management and Tuning
Jan 7, 2017 01:26 PM
chope045
12
Dec 12, 2010 06:36 AM
h.org
Apr 2, 2008 07:24 PM
armanian
Feb 22, 2006 11:54 AM
