b16a pressure plate torque???
Old May 8, 2011 | 05:24 PM
Jdmdelsolb16a's Avatar
Icon2 b16a pressure plate torque???
Hey guys so i read your suppose to torque the pressure plate to 19 FT pounds on a b16 motor and well....i was lazy and just used my impact gun and tightened them down until the gun was struggling but dont worry its not a very powerful impact gun
but after reading the torque spec i used my torque wrenched turned it to 19 FT pounds and all bolts clicked so am i golden?
or am i gonna mess something up if i leave it the way i tightend it down can it mess anything up if its torqued to tight positive feedback please thank you.
Old May 8, 2011 | 06:46 PM
mtber's Avatar
Default Re: b16a pressure plate torque???
If the tranny is off, simply loosen the bolts & re-torque them using a torque wrench.
Otherwise, as long as the bolts are tight, you shouldn't have anything to worry about.
Old May 8, 2011 | 07:23 PM
so if its all put back together with the bolts on tight it wont mess it up?
Old May 8, 2011 | 07:56 PM
mtber's Avatar
Correct, it should be ok as long as the bolts were not stretched which I have never seen a 12 point honda clutch bolt fail.
Old May 8, 2011 | 09:41 PM
Yup I dont think any of the bolts were scratched case closed here thank you sir
Old May 11, 2011 | 06:11 PM
Ek2.4's Avatar
i usually just hand tighten them pretty tight or with an air wrench
Axatax
Transmission & Drivetrain
Jun 28, 2012 09:53 PM
beatthisspeed69
May 2, 2007 07:55 AM
92integracer
Nov 16, 2006 08:51 PM
obliviousSI
Oct 17, 2006 12:34 AM
bruthaboost
Jan 12, 2002 02:54 PM
