Trouble getting speed limiter to work
hey Honda-Tech! I've been messing around with my chipped p05 converted to p28, just trying to get the feeling for tuning and figuring out what you can do with it. I'm starting off with the small things, like rpm limiter and speed limiter; the stuff I understand right now. I'm having some trouble with it though. Most of the time, changing the rev limiter works, although every once in a while it won't change it at all. I can also enable the speed limiter and set it to say 150, and I can get passed 115, so I know that its changed it. But setting the speed limiter to say, 45, does nothing. I can go past 45 like normal. I'd like to understand this and what I'm doing wrong before i go check out other things. thanks for the help
