were to get a base tune?
Old Mar 22, 2011 | 09:21 AM
usdmsol's Avatar
Default were to get a base tune?
Im in the process of building my first motor. Its a high compression b20 vtec. I have a chipped p06. I want to get it running and work out any bugs before i go to get it dyno tuned. It will also be on e85. I have absolutely no tuning experience. What are my options to get this thing running before i get it dyno tuned? The closest tuner is about 4 hours away from me also.
Old Mar 22, 2011 | 10:21 AM
mouab18c1's Avatar
Default Re: were to get a base tune?
Contact Chris at Xenocron.
http://www.xenocron.com/basemap-chip...tom-p-279.html
Old Mar 22, 2011 | 11:14 AM
mtber's Avatar
Running a basemap on e85 isn't usually a good idea unless you have a wideband to monitor things with. Especially on a fresh build!
Do your self a favor, buy a wideband & tunable engine management system like hondata s300 or neptune rtp etc.
Old Mar 22, 2011 | 12:39 PM
usdmsol's Avatar
Originally Posted by mouab18c1
thanks for the link.
I will be using a wideband for sure.
Old Mar 23, 2011 | 05:42 AM
xenocron's Avatar
To work out any BUGS, I usually recommend Stock Injectors, Stock Map Sensor and either a stock ECU or stock mapping for your motor (with o2 sensor turned on).
Once you get those bugs worked out, then switch to the E85 and tune it right away
shoemaker617
Engine Management and Tuning
Jan 10, 2010 06:30 PM
Navy_CRX
Mar 6, 2009 09:45 PM
Frstyl838
Sep 28, 2007 09:54 AM
Viorent Grip! EG
57
Jun 28, 2005 11:44 PM
GruvyTune
Apr 22, 2002 11:27 AM
