target lambda for e85 in racing application
Old May 23, 2011 | 04:57 PM
SPOOLINmatt's Avatar
Default target lambda for e85 in racing application
what is a GOOD target lambda for E85 in a 700-800 hp application, 11:1 compression?
0.85-.086 ish? low 12's with gas numbers?
Old May 26, 2011 | 10:44 AM
SO.GA_SI's Avatar
Default Re: target lambda for e85 in racing application
I wouldnt start that high. My personnel preference is around .71 If you are on a typical (GASOLINE) wideband, 0.71 lambda will be displayed as 10.5:1. Anything in the 12 afrs W/GAS Sensor is asking for trouble in MY opinion.
Old May 26, 2011 | 11:48 AM
12's with gas number is fine, because lambda is lambda. 14.7 is 1 volt on the gas calibrated gauge....which means 1 volt lambda with a gas calibrated gauge on e85 would be 9.7:1.
.71 would be 10.5ish and thats sickening. my car starts to clear up at around .82 lambda which is roughly 12.0-12.1...gas numbers and im trying to see how big the window is.
Old May 26, 2011 | 04:46 PM
SO.GA_SI's Avatar
i think i mis read your post. i thought you were looking for a GOOD (meaning safe) AFR to start tuning with. Sorry for the confusion.
Old May 26, 2011 | 05:21 PM
q16racer's Avatar
you are tuning to the same lambda as you would with gasoline. You just have a bigger window for error with e85 due to its octane content than that of gasoline.
RemerLex11
Apr 12, 2005 06:22 AM
JsNA99si
Jun 16, 2004 02:51 PM
E-Rok
Dec 26, 2003 12:55 PM
Muckman
Oct 4, 2003 02:12 AM
vtec.dc2
Aug 22, 2002 02:03 PM
