need help with 88 hatch
Old Oct 20, 2010 | 11:35 AM
stoneys88hatch's Avatar
Default need help with 88 hatch
can anyone help i have a 88 hatch thats running too rich and has a ecu code 16
Old Oct 20, 2010 | 11:39 AM
2k.civic.si's Avatar
Default Re: need help with 88 hatch
not suprised your running rich....code 16 is a fuel injector problem...
Diagnostic Trouble Code (DTC) System Indicated
0 Engine Control Module (ECM)
1 Heated Oxygen Sensor (HO2S)
3 Manifold Absolute Pressure (MAP Sensor)
4 Crankshaft Position (CKP Sensor)
6 Engine Coolant Temperature (ECT Sensor)
7 Throttle Position (TP Sensor)
8 Top Dead Center Position (TDC Sensor)
9 No. 1 Cylinder Position (CYP Sensor)
10 Intake Air Temperature (IAT Sensor)
13 Barometric Pressure (BARO Sensor)
14 Idle Air Control (IAC Valve)
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor (VSS)
20 Electrical Load Detector (ELD)
21 Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve (VTEC Solenoid Valve)
22 Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch)
23 Knock Sensor (KS)
30 A/T FI Signal A
31 A/T FI Signal B
41 Heated Oxygen Sensor (HO2S) Heater
43 Fuel Supply System
Old Oct 20, 2010 | 11:44 AM
i changed them and it was ok for like 2 days and it came back on
Old Oct 20, 2010 | 11:45 AM
16 Fuel Injector
30 A/T FI Signal A
31 A/T FI Signal B
Old Oct 20, 2010 | 11:59 AM
help
redef90si
Aug 29, 2011 05:09 AM
98tegLSvtec
Jul 31, 2011 01:33 PM
90 ef
13
Jan 24, 2009 07:48 AM
civic889802
Dec 30, 2005 01:04 PM
Audi A4
Apr 21, 2004 08:45 AM
