Maximum timing?
Old Sep 14, 2010 | 07:58 AM
ruffrhyder's Avatar
Default Maximum timing?
Im looking at my basemap, and I was concerned about timing being too high. What is the maximum timing for roughly 12:1 CR, GSR with S2S2 cams at cruising 3000-3500 rpm at around 14-17" vacuum columns.
Mines is at 35-40 degrees
Old Sep 14, 2010 | 09:10 PM
HAMOTORSPORTS's Avatar
Default Re: Maximum timing?
That's within reason.... at 17" you aren't under much load so the chance of causing damage is very minimal. Just try to get good tip-in response in this area and keep your a/f dialed in
Old Sep 17, 2010 | 10:14 AM
jonbar87's Avatar
That should be just about right. With my 10.6:1CR H22 at -14" I'm running about 38* @ 3900rpm
Old Sep 17, 2010 | 01:13 PM
Gunmetal_B20_Hatch's Avatar
Seems about right... I run 44* on my stock Z6 and 43* on my boosted LS in the cruising speed columns. Really helps out with MPG and actually quiets the exhaust down if you can lean it out to ~15.5:1 AFR.
Old Sep 30, 2010 | 12:21 PM
ruffrhyder's Avatar
At cruising 70 mph my AFR is about 16.0-16.2:1
Will adding more timing lean it out even more?
Old Oct 6, 2010 | 08:24 PM
cfwthb_94's Avatar
YES
Old Oct 8, 2010 | 04:11 PM
blackeg's Avatar
that is a little lean. honestly id rather run a tad more timing at that afr on a LOW load setting than too little timing.
i run mid 15's afr while cruising and between 38-42* timing
Old Oct 9, 2010 | 07:16 PM
locash's Avatar
Timing numbers will vary greatly, depending on what EMS you're using.
Old Oct 12, 2010 | 02:43 PM
blackeg's Avatar
also true, i know from experience i can run cars a few tenths of an afr point leaner and with more timing smoother on neptune or s300 than i ever could have pulled off on uberdata or crome free for that matter
a1320honda
Engine Management and Tuning
May 9, 2013 11:28 AM
tianporn
Apr 28, 2008 04:32 PM
b_ron007
Sep 19, 2004 04:22 PM
c-way
Jun 11, 2004 04:16 AM
X2BOARD
10
Apr 8, 2004 05:18 AM
