Question about Actual Timing versus Table Timing
Old Oct 11, 2010 | 02:53 PM
elprovos's Avatar
Default Question about Actual Timing versus Table Timing
First time tuner here with a question about timing. I'm using Neptune tuning my D15B. I recreated a basemap to increase the resolution and I've got the AFs pretty much dialed in on the low cam. My question is about Table Ignition vs. Actual Ignition.
From my datalogging i can see that actual ignition exceeds table ignition by about 3 degrees and as much as 5degrees at almost all loads levels. Do I increase my table values to match actual or do i increase my table values [to match or exceed current actual] in certain areas to increase power?
Old Oct 11, 2010 | 03:39 PM
HRTuning's Avatar
Default Re: Question about Actual Timing versus Table Timing
You tune normally as you would on any other system. You're just now seeing what the stock ECU actually does with the table timing and adjustments.
Old Oct 11, 2010 | 04:02 PM
elprovos's Avatar
hmmm, ok, so even if i alter the values, the ecu will always adjust based on what ever conditions exist. I do have the box checked in Parameters ->main -> options -> Ignition adjustments.
Old Oct 11, 2010 | 04:18 PM
93turbo16's Avatar
There is a background ignition adjustment going on with the stock ECU. NepTune gives you access to this table in the Ignition Dwell section in the parameters section of NepTune RTP.
This will give you the values that are added to the table timing as the RPM increases.
So I wouldn't worry about the table vs ignition difference when tuning. It is there stock, NepTune just gives you access to the underlying rpm dwell.
Old Feb 10, 2011 | 08:42 AM
dellas's Avatar
So when you disable ignition adjustments in Neptune, does it ignore the ignition advance vs RPM in the dwell control section or are there other underlying adjustments getting turned off(I know it doesn't turn off IAT and ECT adjustments)?
If I disable ignition adjustments will it output table values + (IAT & ECT) only like a true standalone would?
I haven't started to mess with those features yet, just want to get a clear picture as to what is actually happening with the stock code and how Neptune handles it before I start using these features.
Old Feb 10, 2011 | 09:16 AM
HRTuning's Avatar
Table + ECT + IAT + gear based.
Old Feb 10, 2011 | 09:51 AM
dellas's Avatar
Ok, great.
So it does ignore the ignition advance vs rpm in the dwell section.
Would zeroing out all ignition advance vs rpm in the dwell section output the same Table + ECT + IAT + gear based?
Correct me if I'm wrong but based on my understanding now it would.
Old Feb 10, 2011 | 10:16 AM
HRTuning's Avatar
No, I'm not sure how you reached that conclusion.
Old Feb 10, 2011 | 10:34 AM
dellas's Avatar
Ok got you.... It's alot more clear to me now..
Thanks JR..
Old Feb 10, 2011 | 10:35 AM
HRTuning's Avatar
No prob.
hmtcrxsir
Apr 3, 2017 05:53 AM
jdmb16ef8
10
May 4, 2008 04:47 AM
type B16
Sep 9, 2006 12:13 AM
the.hamburglar
Oct 14, 2004 11:37 AM
integrx
Jan 15, 2004 11:37 PM
