2step hep needed
Old Aug 22, 2010 | 04:23 PM
sanman000719's Avatar
Default 2step hep needed
ok here goes
i have a b18c1 on an aem-ems, and im building to much in anti lag around 6-7psi wich is killing the slicks off the line
how do i adjust this through the timing in 2 step,and how do i adjust it to lower the amount of boost being made in 2 step
thanx
Old Aug 22, 2010 | 06:02 PM
mtber's Avatar
Default Re: 2step hep needed
If you are spinning your slicks at 6-7 psi, you need to get different slicks or run a different tire pressure.
Concerning adjusting your 2 step/anti lag settings you shouldn't mess with your ems calibration on your own unless you are confident in what you are doing. Contact your tuner before touching your ems.
Old Aug 22, 2010 | 06:07 PM
sounds good
he suggested running less rpm's we hit the track togather frequently actually, and was just talking to him.
well the heat in the midwest around this time of year means mush on the line
jsw_1986
May 1, 2009 03:19 AM
browniiiz
Nov 6, 2008 12:26 PM
nvmyb20hatch
Aug 29, 2006 11:42 AM
ClubSiRacer
Apr 29, 2003 01:10 PM
turbodsmpower
Apr 24, 2003 10:33 AM
