possible to bypass/eliminate speed sensor code obd1 ecu???
Old Sep 18, 2010 | 10:52 PM
1slowcrx's Avatar
Default possible to bypass/eliminate speed sensor code obd1 ecu???
crx running on obd1 chipped crome ecu. not running speed sensor cable. it will throw a code 17 n vtec wont engage. anyway to trick ecu or cluster so it wont throw a code???
Old Sep 18, 2010 | 11:35 PM
4thgenhtch's Avatar
Default Re: possible to bypass/eliminate speed sensor code obd1 ecu???
Just install and wire an electric vss to the tranny, The ecu needs that speed signal..
Old Sep 19, 2010 | 09:45 AM
1slowcrx's Avatar
can you disable through crome?
Old Sep 19, 2010 | 12:11 PM
GhostAccord's Avatar
You can disable the VTEC speed check in Crome not sure if that disables code #17 or not. Crome Gold says disable code #17 (Vehicle Speed Sensor). Not sure if that will help or not.
Old Sep 19, 2010 | 05:56 PM
1slowcrx's Avatar
looking for a definite answer.
Old Sep 19, 2010 | 06:32 PM
I'm guessing that you do not have Crome or tuning capabilities yourself then!
Old Sep 19, 2010 | 08:00 PM
1slowcrx's Avatar
nope! i leave all the tuning n software part for the tuner cus i have no skills in that department
Old Sep 19, 2010 | 08:54 PM
OK. Talk to your tuner and get him to disable the VSS (code #17) on your current tune.
O RLY
Jul 6, 2010 02:06 PM
DeNNis.
Mar 23, 2008 10:48 PM
Josh89SIR
Nov 6, 2007 07:29 AM
crxsi_rcr
Mar 20, 2002 06:08 PM
Drag III Integra
Jan 4, 2002 12:41 PM
