Degreeing cams
Old Oct 2, 2010 | 04:43 AM
speedy8281's Avatar
Default Degreeing cams
Hi guys I'm trying to degree a set of Brian Crower cams on a B18c. They are BC0013 cams. Max lift is 12.60mm. They guy that built the head has already set the valve lash. With a dial gauge on the valve spring retainer it's reading only 11.30mm of lift. Is this because I should be degreeing the cam from 0.00mm lash? Thanks
Old Oct 2, 2010 | 07:09 AM
h22 civic's Avatar
Default Re: Degreeing cams
did you give him the cam card?? he might of just set the cams straight up 0/0
Old Oct 2, 2010 | 10:42 AM
speedy8281's Avatar
The guy that built the head supplied the cams and set the valve lash to suit them.
Old Oct 5, 2010 | 10:29 PM
egycasper16's Avatar
you should redegree them again to make sure that everything is right.
tips:
make the lash @ 0.000 lash when degreeing peakleft.
make the lash @ what the cams company sayes when going to degree to opening and closing volve.
SoHc94
Jun 14, 2011 11:22 AM
eg:R
Dec 16, 2009 04:22 PM
Ryan15
Sep 13, 2006 06:45 AM
velocitytrends
Apr 29, 2004 04:01 PM
